The Building of the Galactic Fleet
Discussion in 'Science Fiction & Fantasy' started by Chadepotts1273, Sep 4, 2015.
  1. Sky Seeker
    Sky Seeker Well Established Member
    All hail the Nerd Lair:bowdown: - I fully endorse and PROUDLY resemble that comment.;):explode::biggrin::biggrin: Love the poster BTW.:)
    Sky Seeker
    :tank:
    Chadepotts1273 and zathros like this.
  2. Chadepotts1273
    Chadepotts1273 New Member
    image.jpg image.jpg image.jpg image.jpg Working on the tiny thrusters, the final few pieces to finish this model. It took a great deal of time & patience for me to put these together. I don't think I've ever had such a difficult time with tiny parts. My first few attempts, ended up being scrapped. But this time, Hulk was smarter than the paper & used a BBQ skewer to wrap the parts around while gluing.;) They still are a bit rough though.
    bgt01, Rhaven Blaack and Sky Seeker like this.
  3. Chadepotts1273
  4. Sky Seeker
    Wow that's tiny!:surprise: Nice detail! Great job! :Bravo:
    Sky Seeker
    :tank:
  5. Rhaven Blaack
    Rhaven Blaack ADMINISTRATOR Administrator
    This is looking good!
  6. Chadepotts1273
    Thanks guys! Here's just a little bit more greebling. The 10 blue dots on top. image.jpg
    bgt01 and Rhaven Blaack like this.
  7. Chadepotts1273
    image.jpg I cut some scrap pieces of the hull to glue around the cockpit & wet it down a little bit, to make it seem to blend into the hull a little better . It doesn't look that great up close, but a few feet away it looks much better. The pics don't really do it justice.
    bgt01, spaceagent-9 and Rhaven Blaack like this.
  8. Chadepotts1273
    image.jpg The Geminon Traveler is finished! Just putting a few final coats of clear coat on her. Would've been done sooner this evening, but had to go outside for a little while & enjoy this double rainbow. Just thought I'd share. :)
    Sky Seeker and Rhaven Blaack like this.
  9. Chadepotts1273
    Absolutely! Fortunately I have a wife that is just about as nerdy as me & very supportive of my nerdy endeavors. She only draws the line at cosplay. I guess I can't got to the Star Trek convention dressed as a Klingon! :(
    Sky Seeker likes this.
  10. Chadepotts1273
    image.png image.png image.png image.png image.png image.png Well, the Geminon Traveler is finally finished! I think I started the rough build of it almost 2 years ago. Then went several months without doing any work on it before I learned about greebling & got back to it. It's a big relief to get her finished! Here are a few final "Glamour Shots" Enjoy! :):adamicon::robot2:
  11. Chadepotts1273
    image.png image.jpeg Here she is joining the rest of my little fleet.
  12. Chadepotts1273
    Next: Continuing work on Revell-Fan's Colonial Movers. :tank:
  13. Rhaven Blaack
    These look GREAT!!!
  14. zathros
    zathros -----SENIOR---- Administrator
    Chade. start cutting off those triangle tabs, and glue a strip just wind enough behind the piece, the other wise, after first side dries, can then be glued to that flat surface sticking out. on the nozzles would have been able to form them into perfectly shape cones, and the seem would be virtually invisible. As the parts get bigger,, this misalignment gets more pronounced, and the problem of white edging appears. By cutting out the tabs, and using the strip method, the surface are on the same plane, and you have no white edges, if you are careful, and have cut the parts perfectly,
    the seams disappear, and turn into panel lines. I suggest giving it a try. It will take your models to the next level! :)
  15. Sky Seeker
    Just get some good friends together and GOGOGOGO!!!:biggrin::biggrin:
    Sky Seeker
    :tank:
    Chadepotts1273 likes this.
  16. Sky Seeker
    Nice job Chad!!:surprise::bowdown::bowdown::Bravo: Looks great on the ceiling with the other ships.:King:
    Thanks for sharing your assembly with us. It's good to see your skills grow with time.:):adamicon: Even with mighty HULK fingers!!;)
    Just had a thought (it happens sometimes);) - have you seen a model of the Rising Star? I'm currently re-watching the original Battlestar Galactica and it's one of the more prominent ships from the old series.
    Just wondering.
    Sky Seeker
    :tank:
  17. spaceagent-9
    spaceagent-9 Right Hand Man and Confidant
  18. Chadepotts1273
    :headbange::headbange::headbange:
    Thanks for that tip Zathros! :) I should have known that already though, guess I was getting frustrated & in too big of a hurry there toward the end . I'll remember that for the next one.:headbange:
  19. Chadepotts1273
    Thank you!:)
  20. Chadepotts1273
    Thank you!:)
