Teach me please...
Discussion in 'General Card Modeling' started by Dancooper, Mar 8, 2007.
  1. Dancooper
    Dancooper Member
    Hi, I am actually more a plastic modeller, but I have downloaded and tried many of those free models available, with variable results.
    My question here is, is there on int this site, or anywhere else a detailed "course" like "Cardmodelling 101" or something ?
    I always print the models on 160grams paper, is this right, or should I only print on that heavy paper for supporting pieces and the rest on regular 80grams ?
  2. cgutzmer
    cgutzmer Guest
  3. thewoodengraver
    thewoodengraver Active Member
    YesSir!
    Click the link " Card modeling FAQ" on my signature.
    If you have any specific questions AT ALL, no matter how dumb you may think it sounds, please ask!
    As for which weight cardstock? Personal preference my friend.
    I use 110# for everything.
  4. Dancooper
    Dancooper Member
    Thanks for the link, that's great help there :yep:
  5. thewoodengraver
    Service with a smile! :grin:
  6. MOS95B
    MOS95B Member
    TWE... You use 110 lb stock for the little stuff, too? I started of with just 80 lb, and found it to be a bit heavy, so I've using 65 lb...
    No wonder you swear by butt joints, you're using lumber, not paper.....
  7. thewoodengraver
    :rofl:
    LOL! well... the Paper Engraver sounds silly now don't it?
    Yes my friend, 110#(lb) for all. As I have also stated..." personal preference" works best.
  8. nebeltex
    nebeltex Member
    yes, personal preference is best... i use 110# for the tanks i build and 90# for the planes. it is a bit easier to curve with the lighter stuff for aircraft. everything i design is intended to be able to be used for activity (including flight for the planes) and the lighter weight paper does not hold up as well for me. another consideration is the relative humidity of your area. it can be discouraging to find a well built model warped to #*&@ after a few months...
  9. Rick Thomson
    Rick Thomson Member
    Hi Major Cooper,
    I use 160 gm/m2 for just about everything. An exception is where I laminate to heavy card, then I use 80gm/m2.
  10. sakrison
    sakrison Member
    I use 65# for just about every download/printout model. It seems to have the right balance between flexibility and stability. My favorite is something called Cougar Cover--very smooth finish. I get it from my local print shop. I've never seen it in Staples or Office Max.
    No worries,
    --David
  11. Bowdenja
    Bowdenja Active Member
    Paper weights can be a bit confusing, because not only do you have to give the poundage, but you have to state which paper you are using.
    Here is a chart that will help to explain.............
  12. Bowdenja
    Continued..............
    INDEX on the chart is the same as CARD STOCK.
    TEXT on the chart is the same as OFFSET Paper
    I use 110# Index (card stock) which equates to 53# bond paper or 90# Bristol.
    So if you are using 90# Bristol paper then you are using 110# Card Stock. Or acutally the equivalent to 110# Card Stock. The paper wights are the same, but the properties of the paper are different.
    If it is 65# COver stock then you equate that to 97# Index.
    Believe me it is way more confusing that it should be, but this is the way it is.
    I hope this chart help explain it better then I can:oops:
    john
  13. Bowdenja
    Also to put things in perspective.......... plain old typing paper is 20# BOND.
  14. thewoodengraver
    John, ole buddy, ole pal,
    would you be willing to do a seperate thread explaining this conversion chart, it could be added to the reserves.
    Very Cool...Thanx!
  15. Clashster
    Clashster Member
    John, as confusing as this is, why is 110 # index equal to 65 # bond? On the chart, 110 index shares a line with 53 # bond.... the room is starting to spin and the head feels like an explosion is in the offing!
  16. Bowdenja
    Clashster you are correct sir! And the room is spinning for me...........dang pollen my sinuses are killing me:cry: I got my columns criss-crossed.
    Phil............... I'll try but believe me with 20 something years of messing with paper.......... It's still a bit confusing to me. The Dang stuff is alive I tell you......... ALIVE!
    The problem is there are several different types of paper.......each having
    specific properties and at some point are the same but different.......... I know......... I know......... you should see me try and explain it to my boss or a Computer Programmer..........they usually jusy throw up there hands and tell me to handle it and they will be happy with whatever I decide.
    It also has the deal with the fact that paper ain't made 8 1/2 x 11 to start with................
    john
  17. MOS95B
    MOS95B Member
  18. Bowdenja
    I agree Mos95B................. I edited my wrong post and added a couple of more things that might or might not help................really IT'S ALIVE I tell ya................ One foot in the air head turned around looking at you to see if you are joining me for the run for the hills....................:cry:
  19. Dancooper
    Dancooper Member
    Hmmmm, ok, I'll go for the styrene and tennax, at least petrol based stuff is easy to understand, it stopped livving 100 million years ago....
  20. thewoodengraver
    Could we get back to a point where I found this easy? Please? lol
    John, if you throw down your tools and go home...I'll understand!
