Stilgar's 3D printer build
Discussion in 'Off Topic Lounge' started by stilgarhammer, Mar 19, 2015.
  1. stilgarhammer
    stilgarhammer Member
    Still working on the wiring for the extruder and X axis.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    zathros and Rhaven Blaack like this.
  2. zathros
    zathros -----SENIOR---- Administrator
    Wow!! You are really banging this out. Very impressive. Just as a suggestion, I would suggest tying the two perpendicular Panels together with either a sheet or bat, as the top round corners, hanging out like that are going to resonate. It looks very professional, and extremely well finished off.! This is a great thread, one of the best. :)
  3. stilgarhammer
    On the top back there is a simple spool holder that looks like this. I have been thinking of doing a threaded rod across and turning the spool 90 degrees. On the mendel90 they often use a teflon tube (the white tube in the right top corner) to guide the filament to extruder, my extruder does not have the tube. So I feel the spool needs to be turned. Still working this out as I get the wiring done.
    [​IMG]
  4. zathros
    Turning the spool, especially with a variable speed feed, will relieve pressure on the printing head. This is where I see these things mess up the most. :)
  5. goodduck
    goodduck Active Member
    Very interesting idea to build your own 3d printer. I thought about it.... but only thought about it.I like turn key. But I am following this with great interest.
  6. zathros
    You can build a better printer, dollar for dollar, if you have the skill and tools, otherwise, you're just one of the crowd. :)
  7. goodduck
    I have no skill and no tools. Be one of the crowd is not so bad. I'll buy extended warranty. :D
  8. zathros
    You're not one of the crowd in anything. O.K., you don't have the tools, but you make the inspiration!! :)
  9. stilgarhammer
    Thought I would update you on my 3d printer build. After I had to put it on hold, I have got back to working on it.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    Now just need to get the programming going, then we can have fun.
    mysteroid likes this.
  10. zathros
    I made this thread a Sticky for a reason. Great job!
