springs
Discussion in 'RC Onroad Forum' started by digdug72, Aug 16, 2005.
Thread Status:
  1. dj6666969
    dj6666969 Active Member
    threaded shocks are good because you can turn the little theaded washer up or down in order to set the stiffness of the spring. This makes setting up for your condition easy, and also changeing its setting is easy too.
  2. digdug72
    digdug72 Member
    so basically it just gives more adjustment after the fact you changed your springs
  3. dj6666969
    any spring u put on the shock can be made stiffer by the threaded washer by compressing the spring.
Thread Status:
