SpaceX BFR anybody?
Discussion in 'General Card Modeling' started by frontiernx01, Apr 28, 2018.
  1. frontiernx01
    frontiernx01 New Member
    I've seen the Falcon 9 and Falcon Heavy paper models at AXM, but nobody has done the BFR yet. I'm hoping someone will do it.
  2. zathros
    zathros -----SENIOR---- Administrator Moderator
  3. frontiernx01
    I need to make that! I am making the Falcon Heavy right now. The landed stage looks good!
    zathros likes this.
  4. zathros
    Go for it, with extreme prejudice!! ;)
    frontiernx01 likes this.
  5. frontiernx01
    I will! I have downloaded and printed it. Gonna try it! The legs look kinda difficult, but hey. I have glue, blades, and a printer (to reprint the mess ups).
    zathros likes this.
  6. zathros
    I would like this to turn into a build thread, and will rename it so if you wish. Nice thing is if you mess up a part, you just print out another. I used to always print out two copies, to make sure the size and ink colors were identical. The n if I needed a spare, or wanted to greeble a hatch, it was easy. You would be surprised how much cutting out a panel lined opening, and replacing it with a flush piece in the area you just cut out makes the model pop. I am surprised more people don't do it, eve doing with very think regular paper has the same effect. ;)
    DanBKing and frontiernx01 like this.
  7. frontiernx01
    Printing a piece on regular paper and putting it over a panel? Brilliant! Adds depth to the model.
    zathros likes this.
  8. snowmanX
    snowmanX New Member
    That is a neat trick re: cutting out a piece and replacing it flush . I learned something I will squirrel away for a future day.
    zathros likes this.
  9. zathros
    To be honest, I used to do this with ESTES Rockets when I was a kid. I am surprised more people don't, as using a thin piece of paper, you can put it over the existing spot, and since they have the same lines, the area thin additional piece compliments the original graphic.. :)
  10. Gandolf50
    Gandolf50 Researcher of obscure between war vehicles... Moderator
    I HIGHLY suggest that you replace the TUBES ... like in the pic displayed if any.. by rolling common printer paper/copy paper ... rolled over a dowel or knitting needle and glued once at the beginning and once at the end.. you can also, then roll your next piece over the first and make telescoping tubes that actually fit and work..and they are smooth and strong when you are done... take the textured piece from the kit and scan that or print that on printer/copy paper at the last few turns and you will not have to paint them! Way better then trying to cut and convert cardstock rectangles into tubes by edge gluing and inner tabs!! They never look smooth!
    snowmanX, zathros and DanBKing like this.
