......On the areas where you may only have restricted access to later on, you may want to do some of the detail now such as dents, nicks, scratches,putting up old of new signs,making rusty nails and nail holes and pre-shading with chalk pastels.
With the use of pastels on dry unfinished rough wood, this is where my method is a little different than most.On most surfaces chalk pastels will easily rub off but on rough wood surfaces they are quite permanent as is, with no fixative required.Remember I am doing a diorama here, so it is just to look at.If I was using the same method on shiny plastic that is meant to be handled,I would roughen up the surface to get a little tooth in it before applying the pastels and then use a pastel spray fixative over that.I will mark that on my list for further experimentation.
For now lets just deal with the barn siding look.OK so now we have this gray transparent surface with a little wood color and grain showing through.Perfect! Lets add some nail holes and rusty nails which is common with most old wood.Find a pattern that you like or just put a few here and there but remember you are probably( in real life )nailing into joists or studs which will create its own pattern.Rather than have a whole bunch of old boards with a straight line of nails running across them which is boring,you may want to create a different pattern.I often use a kind of zig-zag pattern to avoid this.......to be continued(the doorbell is ringing!)
