Sd50f
Discussion in 'Trainspotter ID' started by Triplex, Aug 9, 2007.
  1. Triplex
    Triplex Active Member
    In the 80s and early 90s, a new generation of freight cowl units was made. CN was the primary buyer. All of these models share their overall shape, including the "Draper taper" behind the cab. Thus, they are all often confused, despite not all coming from the same manufacturer.
    GMD (EMD's Canadian subsidiary) made three models, the SD40-2F, SD50F and SD60F. Unlike all other modern cowls, the SD40-2F did not have the 4-window Canadian cab, but the 3-window cab found on early SD60Ms. The common cab on the other four models does slightly obscure the manufacturers' styles, but they are still evident. The SD50F and SD60F (and the SD40-2F) have exposed fans at the rear, curved fuel tanks and HT-C trucks like 70s and 80s SDs.
    There are two main ways to tell an SD50F from an SD60F. From the front, an SD50F has cab numberboards, and an SD60F has nose numberboards. From above, the SD50F has a ridge above the engine compartment which the SD60F lacks.
    RailPictures.Net Photo » Canadian National Railway EMD SD50F SD50F high angle. Note the ridge running forward of the winterization hatch. Also note the C40-8M following.
    RailPictures.Net Photo » Canadian National Railway EMD SD50F Same.
    RailPictures.Net Photo » Canadian National Railway EMD SD50F SD50F leads SD60F.
    RailPictures.Net Photo » Canadian National Railway EMD SD50F SD50F leads standard SD50.
