scratch build Sajuk from Homeworld2
Discussion in 'Gallery & Designs' started by wlock, Sep 10, 2008.
  1. wlock
    wlock Member
    hello
    It's been some time since i have posted here and i had decided to finish a model before doing it again.
    I found some models of the sajuk in different web sites but they where quite difficult to build and none had instructions so i decided to try and create one myself.
    the pic bellow shows the render from the model in the game. I'm using it to create a side view to import into a 3d program
  2. wlock
    wlock Member
    Adding a few more pictures to show the progress of the modeling part
    The 3d model is actually a few boxes modified to fit the scematic view.
    Eventually i realised that the scematic view was not very good and had to redo one in photoshop
  3. wlock
    wlock Member
    pics...
  4. wlock
    wlock Member
    the final parts of the 3d model
  5. wlock
    wlock Member
    this is the model in papekura after i added a texture.
    The color of the original texture is green but i found another pictures that show the model in pale yellow.
    I think it looks much better
  6. wlock
    wlock Member
    and finally pictures of the actual model and of the prototypes.
    the final model is a bit bigger than a A4 page
  7. wlock
    wlock Member
    I'll get better pictures whenever i can get my camera
  8. SEBRET
    SEBRET Member
    This is cool, will you be sharing the model? also the models that already exist on the net cam in the form of PDOs so that is probably why no one made inst for them. I like your take on the model though.
  9. wlock
    wlock Member
    i'm planing on sharing the model as son as i'm done cleaning up the pdf file. there are some errors on the texture but i'll get them fixed
  10. Gearz
    Gearz Member
    You seem to be using the original game textures.. did you have the 3d model extracted from the game..? Not that you needed it = Most impressive work wlock..:thumb:
  11. wlock
    wlock Member
    Actually i used the PDO file made from the game model and in papekura canceled the development, then i choose the option to hide the lines and took a screenshot.
    In Photoshop i edited the size and color, changed the background and played with the contrast, some of the details where not showing up.
    there is also some emboss filter in a few parts
    the picture below shows the 3 stages of modifications.
    i did keep the original in case someone wants a model with the green color.
  12. SEBRET
    SEBRET Member
    Very nice, def like the tan paint job
  13. wlock
    wlock Member
    Adding a few pictures of the model, my camera is working again.
    I'm also rearranging the parts of the model, the pdo file is around 11mb
  14. Jones Brandon
    Jones Brandon Member
    looks good man!!!!!!!!!!!
  15. SEBRET
    SEBRET Member
    both of them look good. when did you build the Akira?
  16. TonyG2
    TonyG2 Member
    Looks really good. I've got the .pdo model from Yesmaster's site but I like your take on the Sajuuk
  17. SEBRET
    SEBRET Member
    Since I'm so excited about this model, I went ahead and popped out an advanced swarmer today. scaled it down to two inches so it's a little rough in some areas. meybe this will provide Homeworld energy to help you with your build, lol
    [​IMG]
    [​IMG]
  18. wlock
    wlock Member
    That looks really good, not to mention really small.
    the Sajuk Zip file is ready to upload, just waiting for instructions since the file is way over the 2mb limit.
    Inside you'll get the 2 textures, the pdo file and a pdf
  19. wlock
    wlock Member
    The model has been uploaded, you can find it in the download section under Homeworld.
    Please post pictures if you actually build this model.
    thanks
  20. SEBRET
    SEBRET Member
    Thank you very much for this fine addition to the set, I think I'll try to be the first to put up pics, lol, maybe.
