Saab J 35 Draken "Ostarrichi" / Geli Modellbau Klagenfurt / 1:33
Discussion in 'Aircraft & Aviation' started by korvette, Jun 2, 2007.
  1. korvette
    korvette Member
    Hi folks,
    starting my building report about the Ostarrichi Draken. The original plane was a tribute of the austrian air force to celebrate 1000 years of austria. Therefore you can find the letters "Ostarrichi" on top of the plane - the first naming of austria in 996.
    The model was reskinned by Michael Klement from austria and the basis is the model No. 48 of Geli Modellbau Klagenfurt.
    Not to tell you a very long story, but the main thing is:
    YOU CAN HAVE THIS KIT FOR FREE !!!
    Just join www.kartonbau.de - the german sister forum, and try it. You will find the model in the download section and yes, we will also have a version in the letter format.
  2. korvette
    korvette Member
    Step I
    Parts: 14 / 14
  3. korvette
    korvette Member
    Construction starts with the first three middle segments of the hull. The method is well known for the plane enthusiast in this community.
  4. korvette
    korvette Member
    Now the segments are finished and prepared for further building process...
  5. korvette
    korvette Member
    First two segments come together - main thing is the clean connection for the letters of the hull skin.
  6. korvette
    korvette Member
    Admin please remove
  7. korvette
    korvette Member
    And the third segment, completing the first section of the hull.
  8. korvette
    korvette Member
    Step 2
    Parts: 10 / 24
  9. korvette
    korvette Member
    Next step is the front section.
  10. korvette
    korvette Member
    Prepared parts...
  11. korvette
    korvette Member
    The cockpit section comes together. As always with Geli models, you have to cut out the opening after assembly of the hull.
  12. korvette
    korvette Member
    The finished front section...
  13. korvette
    korvette Member
    Now, we can connect the first steps...
  14. korvette
    korvette Member
    First result...
  15. korvette
    korvette Member
    Step III
    Parts: 14 / 38
  16. korvette
    korvette Member
    Some sort of mass production...
  17. korvette
    korvette Member
    All segments done, ready for further more work to be fullfilled.
  18. korvette
    korvette Member
    Starting with building of the inner and outer parts of the engine and tail section.
  19. korvette
    korvette Member
    The tail section.
  20. korvette
    korvette Member
    ...ready, steady,...
