RWD-25 from www.modele-kartonowe.com
Discussion in 'Aircraft & Aviation' started by lech, Apr 26, 2005.
  1. jcrespo
    jcrespo Member
    Ditto!
    Joe
  2. Gil
    Gil Active Member
    Swinger,
    Did you use aluminum tooling foil? Beautiful model!
    Gil
  3. J.L.
    J.L. Member
    My goodness, this is outstanding work. So clean and crisp!
    Well Done!
    J.L.
  4. Willja67
    Willja67 Member
    How did you do that gunsight :!: :!: :?: :shock:
    The whole model is very impressive.(I think that's an understatement)
  5. Swinger
    Swinger Member
    Hi,
    1. The landing light is made of transparent foil (the one to be used for inkjet printers). I heated it up over a candle, and then bossed it with a rounded tool. The last thing to do was to cut out the future reflector, sand its edges and paint it silver. The bulb was made with the same method, though I used a smaller tool (and no paint, of course).
    [​IMG]
    2. The alluminium foil was used only for the buckles on the seatbelts.
    3. The gunsight isn't that small, so it wasn't very difficult. The ring is made of paper strip with 4 tiny holes (made with a cut and sanded injection needle), in which the copper wires were put later on. Their endings were cut with a nail-cutter.
    4. Thanks. :D
  6. Swinger
    Swinger Member
    Hi,
    [​IMG]
    4. Thanks. :D
  7. Drakeo1
    Drakeo1 New Member
    An other exelent design I'm once again greatly impressed by your design and modeling quality. Beautiful
  8. Drakeo1
    Drakeo1 New Member
  9. Bowdenja
    Bowdenja Active Member
    Okay Swinger...........the guns............rolled paper or needles??!!
    And I too love the gunsight. You made me give it a try on the model I built for Horus' contest.
    I tried it a little different, all metal except for the hairs from my Sume, who is in the avatar with me.
    And for what it's worth............ this truely is a gorgious model!!!! As are all I seen that you have built!
    john
  10. Bowdenja
    john
  11. Swinger
    Swinger Member
    Needles. 8)
  12. Swinger
    Swinger Member
    Needles. 8)
