rotary engines
Discussion in 'Gallery & Designs' started by Richard, Apr 26, 2006.
  1. 46rob
    46rob Member
    Does this picture help? In the radial, the crank turns, in the rotary the crank is stationary and the engine turns. The stroke is determined by the displacement of the crank form the center of rotation, just like a regular automobile engine.
    The master rod is the same as a single cylinder engine's. It rides on the eccentric of the crankshaft and the other cylinders slave off of it, like in the picture.
  2. 46rob
    46rob Member
  3. shrike
    shrike Guest
  4. shrike
    shrike Guest
  5. Bengt F
    Bengt F Active Member
    Inside a Radial Engine
    Thanks Rob and shrike,
    That explains the basic functions in the best possible way. From now on, I´ll know for sure the difference between a rotary and a radial engine.
    best regards,
    Bengt:rolleyes:
  6. Bengt F
    best regards,
    Bengt:rolleyes:
  7. jyduchene
    jyduchene Member
    Rob and Shrike, Thanks for the explanation. A mystery solved. The animation again helped much. I appreciate you both taking the time. John
  8. jyduchene
    jyduchene Member
  9. Richard
    Richard Member
  10. Richard
    Richard Member
