Rollin' Your Own (Wheels)
Discussion in 'Tips, Tutorials & Tools' started by Fishcarver, May 10, 2006.
  1. Fishcarver
    Fishcarver Active Member
    One of the aspects of cardmodelling that I do not particularly enjoy is the making of wheels and tires out of numerous bits of card; especially if I am scratchbuilding a project. (As I have done with my 2P26 GAZ 69 ATGM Jeep). So, here's a little tutorial called "Roll Your Own" (wheels, that is).
    As a wildlife woodcarver, I usually have a plentiful supply of wooden dowels of various sizes lying about the shop. In Photo #1 we see: a representative piece of wood dowel, measurement being taken off the tech drawing, a slice of dowel, and locating the center using a center-finding square.
  2. Fishcarver
    The trusty Dremel Tool
    Drill a small hole into the center of your "wheel blank", so as to be able to attach the wheel to a mandrel on your trusty DREMEL tool.....
  3. Fishcarver
    ...because your chosen slice o' dowel is likely to be just a bit oversize. We spin the dowel against a sanding block to reduce the diameter and, at the same time, shape the tire shoulders.
  4. Fishcarver
    Continue spinnin' and shapin' until your wheel/tire is of the proper diameter and profile.
  5. Fishcarver
    The center of the wheel/tire can be carved out as necessary. In this case, we have used a 3/8" (9mm) cylindrical carbide burr (KUTZALL):
  6. Fishcarver
    After a few minutes work, we have a nice, uniform set of wheels all ready to install on our model. The photo below shows a turned wheel, card hub inserts, the painted wheels and wheel installed on an axle.
    Rollin' Your Own!! It's Fun!!
    Jim
  7. Fishcarver
    In a future "advanced" tutorial, I'll demonstrate how to put lugs and directional treads on, using the DREMEL tool and a woodburner.........
    Jim
  8. jasco
    jasco Member
    I have done essentially the same thing with layers of chipboard, the advantage being that I can turn outer rings to make the wheel look like a tire mounted on a wheel. It also satisfies the "purist" in me by sticking to paper.(Although I do use wire, toothpicks, etc when the mood strikes) I'm sure we will all be interested to learn how you use a woodburner(!) to put in treads. Many of my models end up in the woodburner after frustrating attempts to build them!
  9. Fishcarver
    Jasco: go here and take a look!
    http://www.razertip.com/catalogue.htm
    The "woodburner" to which I refer is actually a "pyrographic pen". The woodburner to which you refer is, I belive, called in these parts a "Quebec heater" :)
    Jim
  10. badwargamer
    badwargamer New Member
    Hi....Great tip.
    Can I ask where did you get the centre finding square?
    Adam
  11. Fishcarver
