Rolland C.II Beta Build
Discussion in 'Aircraft & Aviation' started by Getter1, Nov 18, 2007.
  1. Getter1
    Getter1 Active Member
    Hello All,
    I decided to post my Beta build in a new thread.
    For my beta builders post your feedback in this thread.
    I'm building it at 1/72 scale. THe parts are printed on white construction paper as I find it the best thickness for this scale.
    First pic shows the main body parts laid out. The body sections have had regular paper tabs added. On the left are the bulk heads, Gunner's ring, Wing and Tailplane Struts, all doulbled up. As well as the Seat, Seat Mount, and Engine compartment.
    Getter 1
  2. Getter1
    Here we have the seat mounted, the engine compartment painted, and the bulkheads assembled and painted.
    G1
  3. Getter1
    A couple shots of the seat mounted. I also developed in the process the control stick and the rear gunner's seat.
    G1
  4. Getter1
    The insides of the cockpit body sections are painted and rolled.
    G1
  5. Getter1
    Here the windows are made. I taped a piece of clear plastic over a print out of page 1. I then cut out the frames of another print out and painted them. I then glued the frames on to the plastic over the part layout. When dry I cut around the frames. They were then glued into the rolled body sections.
    G1
  6. Getter1
    The windows in place.
    G1
  7. Getter1
    Attaching the body sections over the cockpit.
    G1
  8. Getter1
    Adding more sections.
    G1
  9. Getter1
    Add the filler piece for the gunner's section and when dry carefully trim off excess.
    I designed it that way because it was a pain to trace out an accurate part (3 failures).
    G1
  10. Getter1
    Add the engine compartment and the last nose section. When dry pierce the front disk with a straight pin for the prop shaft. Note the Gunner's ring assembled and painted nearby.
    G1
  11. Getter1
    Gunner's ring installed.
    That's all I got for now folks :D
    Opinion's thusfar???
    G1
    P.S. I always wonder why my pics look so much better in my PC than they do after being uploaded???
  12. cgutzmer
    cgutzmer Guest
    very cool! thanks for the pics and great tip on the windows :)
    Chris
  13. Gregory Shoda
    Gregory Shoda Member
    Your model looks very intriguing so far. Good choice of subjects!
  14. kampfflieger
    kampfflieger Member
    Very nice model! I like it!
  15. Getter1
    cgutzmer, Gregory Shoda, and kampfflieger, thanks for the kind words.
    I finally got a chance to get a bit more work done this evening.
    Here I have cut out the top wing mount hole and the tailplane slot.
    Getter 1
  16. Getter1
    Tail surfaces mounted.
    G1
  17. Getter1
    I couldn't use toothpicks for wing alignment and root reinforcement as I did on the prototype. The toothpicks would be way too large for this scale so I adapted wing boxes taken from Marek's Pfalz D.III sized down and extended to fit the Roland's wings. It worked so well I whis I had used them on the prototype :p
    G1
  18. Getter1
    Here's a dry fit of the wings. I still have to trim the edges but that'll have to wait till tomorrow. It's late, I'm tired, and my eyes are getting squirly, a disaster in the making if I push it any more :p
    G1
  19. rmks2000
    rmks2000 Member
    Looks good!
  20. Alcides
    Alcides Member
    Looks very good. :thumb:
    by the way, I don't see any problem with your pictures.
