Rivets
Discussion in 'Tips, Tutorials & Tools' started by paul a, Apr 20, 2007.
  1. paul a
    paul a Member
    I,m building 46rob,s t-33 in 1-1 scale for an RC project. is there a tool I can use to form rivets in the cardstock. it would not look good without them.As you can see. Thank you paula
  2. paul a
    paul a Member
  3. cgutzmer
    cgutzmer Guest
    I would press on it gently with a retractable ball point pen (without the pen sticking out just ot be clear) You would need to find one small enough though. There is also the option of picking up some brass tubing from a hobby store. Never done it myself but this seems like it should work.
    Chris
  4. cgutzmer
    cgutzmer Guest
    Chris
  5. paul a
    paul a Member
    Size is not to much of an issue the aircraft is 37 inches long.maybe the balpoint and some ink.
  6. paul a
    paul a Member
  7. Bowdenja
    Bowdenja Active Member
    Check out the sewing section of a local store............craft or discount. Pick up one of those trace marking things they use to mark the pattern on the fabric.
    If the spacing is not right/to scale you could remove/grind off some of the points. Then all you have to do is follow the panel lines.
    Ummmmmmmm post some pictures of the build I know Rob and the rest of the DGA guys would be interested.
    john
  8. Bowdenja
    john
  9. paul a
    paul a Member
    thankyou the better half sews maybe she has one.do you use it from the front or back.I know rob would be interested I felt that when I asked his permission to use his design.
  10. paul a
    paul a Member
  11. rickstef
    rickstef Guest
    it is called a pounce wheel
    and you use it on either side, front side would best
  12. rickstef
    rickstef Guest
  13. paul a
    paul a Member
    Thank you I have to get one at michaels arts and crafts when I go to get some more alumium card stock this is going to eat alot of it.
  14. paul a
    paul a Member
  15. 46rob
    46rob Member
    Remeber--the T-33 is flush riveted--so there shouldn't be any dips or bumps where the rivets are.
  16. 46rob
    46rob Member
  17. charliec
    charliec Active Member
    I remember there was a build thread on a Ju-88 where the constructor used a ground down syringe needle to imprint the surface with circular indents to emulate flush rivets.
    Most aircraft used low profile rivets so they would hardly be noticeable as a bump above the surface in 1/33 scale.
    Regards.
    Charlie
  18. charliec
    Regards.
    Charlie
  19. paul a
    paul a Member
    thats why i think i,ll ink them in thank for the reminder. as a crewchief had to count the poped one allowed so many in a area.
  20. paul a
    paul a Member
