"ribbed" Aircraft ?
Discussion in 'Internet Finds' started by bfam4t6, Jan 27, 2005.
  1. chajal
    chajal New Member
    Que avion es? Who airplane is?
    :D Hola estimados foristas les dejo un reto de identificar con una solo foto que avión estoy acabando (si no me acaba el antes :D :D )
    Hi forum!
    What plane i bulding now?
    [​IMG]
    (Atención es la misma foto / Same photo)
    [img=http://img101.imageshack.us/img101/7968/mmmyr6.th.jpg]
    Espero que lo disfruten.
    I hope enjoy it.
  2. Willja67
    Willja67 Member
  3. milenio3
    milenio3 Active Member
    La pones dificil... un P-40?
    Hard to tell... a P-40?
  4. 3Turner
    3Turner Member
    looks like a P-51
  5. chajal
    chajal New Member
    mmm...
    Caza Figther
    No tiene armas en el ala - No weapons on wing
    Motor radial 14 cilindros - Radial Engine 14 pistons
    Vean el timon y la punta del ala - Check wingtip and rudder
    Sigan intentandolo
  6. Bowdenja
    Bowdenja Active Member
    T-6 Texan?
  7. chajal
    chajal New Member
    Un tip mas
    No es americano
    One more tip
    no american
  8. Bowdenja
  9. chajal
    chajal New Member
    No. El A6M tiene cañones en las alas
    No. The A6M have guns in wing
  10. rmks2000
    rmks2000 Member
    Chajal,
    Any status on the other aircraft you are designing? Also, Is the Me-109 complete? It appears to be missing the parts for the fuselage.
  11. JLKasper
    JLKasper New Member
    Mystery plane
    Hmmm...
    Methinks Japanese, early WWII...
    No framework around wheelwells, suggests fixed landing gear.
    Rounded rudder, eliminates A5M Claude.
    Twin machine guns in cowl, radial engine... Ki-27 Nate?
  12. 57townsman
    57townsman Member
    Are you finally getting around to the A6M2-N Rufe??
  13. Lex
    Lex Dollmaker
    I've been to this site a long time ago, and... Is it still being updated?
  14. chajal
    chajal New Member
    El avion misterioso era el Ki43ii
    El Ki43ii esta listo, pero aplican restricciones.
    Bueno, para terminar rápido y se animen por un Ki43ii vamos a armarlo paso a paso
    Seleccionamos el área del fuselaje
    [​IMG]
    Las piezas 6 y 5 las reforzaremos (hay que recordar que se usaran hojas comunes, las mismas que se usan en fotocopias) pegándolas sobre otra hoja
    [​IMG]
    "Desprendemos" del papel las piezas
    [​IMG]
    Hay que notar que la pieza 3 se dobla.
    Las piezas 1 y dos sirven para hacer una "caja"
    [​IMG]
    Acá vemos que la pieza 3 se pega sobre la 5. Y se muestra la "caja" formada por las piezas 1 y 2
    [​IMG]
    [​IMG]
    Ahora ya piezas puestas "sobre" la pieza 4 antes de "envolver"
    [​IMG]
    [​IMG]
    Continuaremos...
  15. chajal
    chajal New Member
    Recapitulemos lo avanzado con este diagrama. (la parte mas dificil para mi, hacer el manual)
    [​IMG]
    Ahora empezaremos con las alas, y empezamos con la parte 4 (del ala y son dos) se cortaran y se doblaran y se pegaran como se muestra en la siguiente foto (hay que recortar las muescas antes de pegar al fuselaje)
    [​IMG]
    Ahora siguen las "vigas" que son tres (por ello no llevama armas en las alas) y las reforzaremos pegandolos en otra hoja de papel
    [​IMG]
    Aqui se muestran "desprendidas" las piezas (hay que hacer los agujeros de la pieza 1, ya que por ahi pasara el tren de aterrizaje)
    [​IMG]
    Ahora "presentamos" los tanques de combustible
    [​IMG]
    y como quedan armadas
    [​IMG]
    Como se integran con las "vigas"
    [​IMG]
    y empezamos a pegar los tanque con la viga frontal (pieza 1 del ala)
    [​IMG]
    Mientras pegaremos la pieza 2 al fuselaje
    [​IMG]
    y luego la pieza 1 con los tanques
    [​IMG]
    Seguimos con los otros tanques
    [​IMG]
    Y por último la viga final (pieza 3)
    [​IMG]
    Seguimos con la pieza 7 (un poco de papel picado)
    [​IMG]
    Y listo "desprendido" y predoblado
    [​IMG]
    Empezamos a pegarlo con cuidado
    [​IMG]
    y el ala ya esta pegada en el fuselaje (faltan detalles, flaps, alerones, tren de aterrizaje)
    [​IMG]
    continuaremos.....
  16. rmks2000
    rmks2000 Member
    Beautiful work!
  17. chajal
    chajal New Member
  18. Gracias por compartir Chajal!
    Se ve espectacular.[​IMG]
    Pero no puedo entrar a tu página en Webcindario :'(
  19. chajal
    chajal New Member
    :( ya me di cuenta, esta saturada.
  20. chajal
    chajal New Member
    mmm... ¿Cual hare?
    What shall I do?
    Acá mejorando el I-16 con más detalles y versiones, se aceptan sugerencias.
    Here, improving the I-16 with more details and updates, accept suggestions.
    [​IMG]
    [​IMG]
    [​IMG]
    y por otra parte estoy terminando este avión
    and moreover I am finishing this aircraft
    [​IMG]
    No he actualizado mi página aun, espero tenerla en la semana lista.
    I have not updated my page yet, I hope to have it in the week list.
