rhino3d help needed
Discussion in 'Tips, Tutorials & Tools' started by yaniv, Jan 22, 2007.
  1. yaniv
    yaniv Active Member
    i start play with my rhino and read lots of tutrials
    but i have somthing i dont know how to make
    the pic will show my problem
  2. Willja67
    Willja67 Member
    I'm going to need some clarification to understand what you want.
  3. paper warrior
    paper warrior Member
    An answer to the pic.
    That circle is to make it look like it's moving. Just Frankenstien a bit and take the prop from a different drawing.
  4. nx13688
    nx13688 Member
    I think the problem is that the background bitmaps are not scaled and aligned properly. You need to draw some guide lines the length and height of the fuselage and use them to align the bitmap images.
  5. Willja67
    Willja67 Member
    Also It looks like you are assuming the fuselage is perfectly cylindrical. It isn't.
  6. yaniv
    yaniv Active Member
    some one can please show me step by step what i need to do?
    i realy new to this program and design world
    i read alots of tutrials but never found how to fix my problem
  7. Willja67
    Willja67 Member
    My first suggestion is to not mess around with meshes when starting. Like Nebletex said make sure all your views are scaled correctly before starting then trace the plane. If you would send me the Rhino file and also the bitmap files you are using I can show you how I would do it and maybe help start you in the right direction. PM me if interested.
  8. catalin
    catalin Member
    where have you seen the tutorials? give me a link, please.
    catalin8)
  9. catalin
    catalin Member
    catalin8)
  10. yaniv
    yaniv Active Member
