Rhino: Model finished. How I draw the panels, details?
Discussion in 'Gallery & Designs' started by Alcides, Apr 30, 2007.
  1. Alcides
    Alcides Member
    My humble model in rhino is finished. Seems to be a plane !!! :wink:
    [​IMG]
    Now, I need a to add the panels, marks, etc. How I can do that?
    I have tried drawing curves over the surfaces but when I unroll the surfaces the curves don't develop with the surfaces. :cry:
    Any ideas? Sugestions?
    English isn't my native language so if I'm not clear tell me. I can try to explain myself in another way.
    Thanks to read.
    Alcides
  2. yaniv
    yaniv Active Member
    its looks a nice work my friend
    cant wait to the test built
    well my c47 not mach progres not have mach time for it
  3. yaniv
    yaniv Active Member
    what u mean about this line
    "I have tried drawing curves over the surfaces but when I unroll the surfaces the curves don't develop with the surfaces."
    can u please explain me?
  4. Maurice
    Maurice Member
  5. Lex
    Lex Dollmaker
    Just to add the "Intersect" command is quite handy. I recommend both of them.
  6. Alcides
    Alcides Member
    Yaniv
    Thanks for your comments. I'm going to explain myself below.
    Nezar
    Thanks. Rhino has a lot of commands. I've to try this.
    Maurice
    Well, you recognized the airplane. So I think the model is good.
    Thanks for the link to Nobi's blog. What really help to solve the problem were the pictures.
    I was doing more less what's nobi wrote. I was drawing in a layer the marks and panel lines. but When I projected the layer over the surfaces this goes in the wrong way.
    My mistake was to use the whole model. I was drawing in the layer and projecting the curves over the whole circular surfaces.
    If you see the Nobi's work he works over the half of the model. This is the correct way. I just split the model in half. Next I projected the curves and all is ok.
    I'm working now. I'm going to put some pictures to clarify when I'm back at home.
    Thanks for your help.
    Alcides
