Resetting Carb. Settings :(
Discussion in 'RC Offroad Forum' started by Justin_E, Aug 6, 2004.
Thread Status:
  1. redheat
    redheat Member
    Dude you crack me up, Brother dont toast your AE.15 thats a really good motor, get the most out of the motor first. Now back to the ae you said that the arm is bent well thats were your L/S is located. When you put that thing back together make sure that your linkages are correct or youll have that motor screaming bloody murder when you go to starting it , just go back on the things that we talked about as far as set up. Now let me say this providing you did everything correctly with the retrictor out of the carb. that motor well haul but. If you run into a problem try and figure it out , you have a manuel right? Most important set that idle with the TX and truck ON. RED
  2. daytondaft
    daytondaft Member
    sry to interupt ur topic but i have a .15 ae engine as well and i still have the white restricter piece in it. So should i just pop it out?? will it make my engine run hotter?and increase the speed.
    thanks,
    Dayton
  3. Justin_E
    Justin_E Member
    Well from what I heard it will give you more power but will make your engine run hotter.
  4. Justin_E
    Justin_E Member
    OK, thanks, Ill get back to you when I do all of this......
  5. redheat
    redheat Member
    E, did you get your carb. working? RED
  6. Justin_E
    Justin_E Member
    Im still waiting for the throttle arm or whatever its called. Me and my bro are going to go pick his Savage up today at the LHS so I might get it if they have it in stock...
  7. redheat
    redheat Member
    Cool ,,,RED
  8. Justin_E
    Justin_E Member
    Well the LHS has to order the throttle lever so they said they might get it in Friday
  9. redheat
    redheat Member
    Right on I'm guessing you'll have it running by SAt. RED
  10. Justin_E
    Justin_E Member
    *sigh* I got everything together and I also bought a fuel filter, the carb settings look fine. I started it up and it started acting real weird. It would idle really high, then Id put the throttle on and it would go low and not do anything and die. I tried it like 5 times and I couldnt get it to run good at all....:(
  11. Justin_E
    Justin_E Member
  12. redheat
    redheat Member
    Send a pic of the carb. ,from the side and down the throat make sure that the rx,tx are on and at idle setting , dont start it yet, RED
  13. Justin_E
    Justin_E Member
    What are the rx and tx?
  14. dj6666969
    dj6666969 Active Member
    radio and reciver
  15. Justin_E
    Justin_E Member
    thats what i figureed
  16. redheat
    redheat Member
    Right on , so hows things running, RED
  17. Justin_E
    Justin_E Member
    well i think i fixed the problem but now i just have to save up for some fuel lol, im running 20% now
  18. redheat
    redheat Member
    Good choice , could I suggest Trinity Monster Brew 20% great for bashing and it has a rust inhibator in it, RED
  19. tfhughes_28
    tfhughes_28 Member
    Hey Red.
    Just wanted to say that it is great to see you helping out this guy so much. Most people can't be bothered to help out in great detail like you are, and guys get frustrated and quit the hobby. There are a few guys that have help me out in my times of need (isn't that right SteveM....lol). It makes the hobby better when you have fellow hobbiests willing to help out when your in a fix. Anyways...just wanted to give credit where credit is due.
  20. monsterrcbuilder04
    ya red is great. there were people who helped me out with all the questions i had and didnt get mad even if they were really stupid questions
Thread Status:
