request help for battery configuration
Discussion in 'RC Drifting and Setup' started by paikia, Mar 24, 2005.
  1. paikia
    paikia New Member
    :cry: i jus bought some new batteries, however, i dunno how to join them.. i know of normal series set up but i would like to set it up in other ways.. can any one help pls?
  2. SpArKeY_STi
    SpArKeY_STi Member
    what is your application? What type of batteries are they? Can you solder?
  3. 69stang
    69stang Member
    you need to tell us more info. like what type of car or truck do u have how many cells do u wan to run. and what do you mean by different type of setup
  4. rcdrifter
    rcdrifter Member
    Also more important than if your wiring parallel or in series, are these matched as especially with rc packs to get the highest punch out they need to be matched..
  5. paikia
    paikia New Member
    I'm using xpress junior pure 10, 6pc batt, running on integy 13x6 motor. used to be "stick" style. I got a set up in mind but i cant put it into words.. i saw the xpress website, special mod, he placed the batt on the chasis in the way i want.. ut i cant figure out how he does it..
    Please pardon me as I'm a noob... I wanna learn but i have no one to consult...[/img]
  6. paikia
    paikia New Member
    Yes I can solder.. I bought some batt pads, but figured i can use wires.. on top of this batt configuration, I wanna ask about charger too.. Wats the cheapest charger i can get to charge n discharge my GP level 1 3300 batt?
    I am currently using a charger by speed model EX-14 its a little slow... 45 min to finish charging at ~4A
  7. SpArKeY_STi
    SpArKeY_STi Member
  8. SpArKeY_STi
    SpArKeY_STi Member
    Quick chargeing is BAD. thats accually about average for a super charge on my BC110A (About $150). For $60, you can get a Intellipeak small charger. Its a great little charger i have it.
  9. paikia
    paikia New Member
    Thank you..
    thank u sparky, for showing me that website.. i managed to find a suitable config that probably works for my car..saddle up (mod)
