[report] Junkers Ju 88C-6 (Military Model, 3-4/2003)
Discussion in 'Aircraft & Aviation' started by Swinger, Jun 17, 2004.
  1. Leif Oh
    Leif Oh Member
    Thanks for the tip about the eraser - very nice! And, again, congratulations on the superb work & photo. Learning every time. - L.
  2. Swinger
    Swinger Member
    OK, now go the horizontal stabilizers. Look how many parts are needed to build them - however, they look just like the real ones. ;-) What's more, numerous and large formers make the components very stable and almost impossible to twist.
    [​IMG]
    The endings have I made using the rubber gum technique:
    [​IMG]
    The trim tab (originally not to be cut out):
    [​IMG]
    And this is an almost-finished stabilizer (the parts which link the rudder to the stabilizer will be added later):
    [​IMG]
    [​IMG]
  3. Leif Oh
    Leif Oh Member
    Beautiful! - L.
  4. barry
    barry Active Member
    Perfection
    barry
  5. Jim Krauzlis
    Jim Krauzlis Active Member
    Outstanding job! :D
    Flawless work on the construction, and superb photos to give us all a treat! :D Thanks!!
    Cheers!
    Jim
  6. jasco
    jasco Member
    I just found this link and, like the rest of us, I'm stunned. I threw away the Spaceship One I'm making and started another as a result of your work. It should be noted that English could be a second language for you ( I hope I am not being rude) and it is stunning, too. I know I don't speak Polish! Thanks for sharing this with the world.
  7. cmdrted
    cmdrted Active Member
    very simply "arcydzielo", masterpiece from a master ,bardzo dziekuje :!:
  8. yaniv
    yaniv Active Member
    hi ther all
    firs af all the model look very empresiv :)
    i just got my ju88 today with the p51 by halinsky
    this 2 models are just good looking and deiteling
    way wan i go to the first topics in this trad i can see the pic :(
    its can be very helpful to me with the ju88 :(
  9. Swinger
    Swinger Member
    Hello again. :) The build slowly goes on - here come the engines:
    [​IMG]
    Firstly, the exhaust pipes. Unlike armour or ship modellers, aircraft builders usually haven't got much to do with "recurrent" parts (maybe that's why I mostly build aircrafts :) ). Unfortunately, there are exceptions. ;)
    [​IMG]
    The edges fit to one another better when they have been sanded just like that:
    [​IMG]
    That's how the endings were shaped (the green thing is a 1 mm wire):
    [​IMG]
    The formers of the engine (firstly I put the basis for the pipes, then I've added the pipes, and finally the skinplate):
    [​IMG]
    After covering with the skinplate (the instruments in the black circle have been cut out, glued to circle made of transparent foil and glued back to the skinplate):
    [​IMG]
    [​IMG]
    [​IMG]
    With the front part:
    [​IMG]
    [​IMG]
    A little painter's mistake:
    [​IMG]
    I cut out a part of the blue-gray side... The lacking other side's part will be added later.
    Damn... Now I've realised that the pipes will not be HARDLY visible (as I had thought), but ALMOST invisible under this cowling:
    [​IMG]
    [​IMG]
    Well, these covers must have been removable, so I'll leave one engine without them. :)
    Now the engines are ready (not all the edges in the engine in the rear - or in the left on the second picture - have been already painted):
    [​IMG]
    [​IMG]
    These three photos should help figure out how these parts should be put together (the assembly instruction is a little confusing here):
    [​IMG]
    [​IMG]
    I had to cut out holes in the former below to make place for the air intakes:
    [​IMG]
  10. Swinger
    Swinger Member
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  11. yaniv
    yaniv Active Member
    swinger
    i not have words
    your work is ******** outstending man
    i have this mosdels at home for 1 year +- and i so jales your work
    u gave this paper new life
    i still looking for the guts to start it :)
    hoppe to see more of your pic and yore works
    kip doing the killer work
  12. yaniv
    yaniv Active Member
    swinger
    i not have words
  13. Swinger
    Swinger Member
    I've covered one of the wings.
    [​IMG]
    [​IMG]
    [​IMG]
    Bigger not supported surfaces have been stiffened with additional layers of card.
    [​IMG]
    [​IMG]
    This prevented the skin from falling down. The surface is now very smooth (photos against the light):
    [​IMG]
    [​IMG]
    [​IMG]
    This is the biggest wing I've ever built. The fitting and general design idea of the formers are quite ingenious! I didn't have to think about keepeing the ribs in line, because the skeleton just doesn't bend. Building wings has never been so much fun. :) Hats off to Marcin Grygiel again. :)
  14. Swinger
    Swinger Member
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  15. Bowdenja
    Bowdenja Active Member
    Swinger.......... That is amazing! What is the span on that model?
  16. Bowdenja
  17. Swinger
    Swinger Member
    It will be more than 60 cm. :)
    One more thing - a hint for forming the wings' leading edges. To fold a part it is good to do this:
    [​IMG]
    ...a few times, using a tool of a smaller diameter each time. However, sometimes it doesn't help, and then it is good to soak the part at the non-printed side with a little liquid (a VERY small amount!). Water isn't good for this in my opinion, because it's too thin, but... saliva is just perfect. :D It's a lot easier to make a leading edge of a very small diameter using this method, when compared to "dry" modelling.
  18. Swinger
    Swinger Member
    [​IMG]
  19. GT5500
    GT5500 Member
    That wing is beautiful, its better then some of my balsa models! maybe you could do a sort of tutorial on how you build the wings.
  20. GT5500
    GT5500 Member
