[report] Junkers Ju 88C-6 (Military Model, 3-4/2003)
Discussion in 'Aircraft & Aviation' started by Swinger, Jun 17, 2004.
  1. mark
    mark Member
    oky dude thanx
    i start cut some fislegs part with knif only at the start it not go so good but now i make 2 grat ones :)
    what is the tool in the front off the firs knife
  2. Swinger
    Swinger Member
    You mean this white one? This is just a cover for that knife. :)
  3. mark
    mark Member
    hahahahah
    how u use it in modeling :)
  4. rickstef
    rickstef Guest
  5. Swinger
    Swinger Member
    OK... Now I'm completing the interior's stuff. These are ammo boxes (feeding previously built machineguns).
    [​IMG]
  6. Swinger
    Swinger Member
    Now I'm using Photobucket, so I can throw in more photos. ;)
    Here's a new hole in the floor: ;-)
    [​IMG]
    This is an artistic shot of the fuselage with the hole in it... and my fingers: :)
    [​IMG]
    And this one is to make a little summary. The parts are not glued to the cockpit. It's just to show what it's going to look like. And one more thing: building this model gives a lot of fun, because the parts fit in 99%.
    [​IMG]
  7. jrts
    jrts Active Member
    Hi Swinger
    Outstanding just amazing all the fine detail you have put into this model.
    Look forward to seeing the rest.
    Great work :shock:
    Regards
    Rob
  8. Jim Krauzlis
    Jim Krauzlis Active Member
    Looking suberb, Swinger!
    Great news to hear the parts fit so well. Makes things a bit easier, what?
    Such detailed work, it's a extraordinary job! :D
    Jim
  9. Swinger
    Swinger Member
    Thank you friends. :)
    This is the instrument panel:
    [​IMG]
    And that's how the glasses and bezels had been done:
    1. I'm glueing the rings to the panel,
    2. I put PVA into the rings,
    3. As soon as the glasses are dry, I'm making the screws out of PVA drops,
    4. I'm proud of myself. ;)
    [​IMG]
  10. jrts
    jrts Active Member
    Hi Swinger
    And so you should be proud of it :shock: amazing work
    Thanks for the how you did it
    Regards
    Rob
  11. barry
    barry Active Member
    bezel glass
    Swinger
    Brilliant idea looks fantastic
    barry
  12. Texman
    Texman Guest
    Nicely done. I do have a question about the instrument bezels.
    Did they come with the kit, and how did you cut them out? Punch
    and die?
    Also, I wonder how Micro kristal kleer would work compared to
    the normal PVA for the lenses?
    Outstanding work
    Ray
  13. cecil_severs
    cecil_severs Member
    Swinger, pretty amazing work. I find the photography just as impressive as the modeling work.
    I also do wonder how something other than PVA would work for the instrument lenses. I'm thinking of the JudyKins Diamond Glaze product.
    Cecil
  14. 57townsman
    57townsman Member
    WOW! :shock: That is one beautiful panel! Are the instrument rings wire? They look like it, using a technique similar to Scorpio's portholes?
    Thanks for the great pictures and inspiration!
    Steve
  15. Swinger
    Swinger Member
    In the kit was there only the panel itself. The rings are made of copper wire, with the same method as Scorpio used in Rodney's illuminators.
    As for the glasses, they can be made of anything that dries glossy and transparent and have some glueing abilities. In Fokker I used a floor varnish and it was good, too. :) Unfortunately, I haven't heard about the mixtures you've mentioned, Texman & Cecil. ;) You'll have to try them out.
  16. Swinger
    Swinger Member
    This is an update of the panel:
    [​IMG]
    A warning for those who want to build the model - you must not grind the 15b+15c former! The instruction doesn't say anything about that... Usually in such cases they order to grind the edges. Here, it was noxious (in my case; that doesn't have to mean anything)... I'm just showing a dangerous moment! ;) Check everything three times before glueing, future builders.
    It's this former:
    [​IMG]
    Here I also encountered a problem - probably I used a too thick card in the formers in the segment following the cockpit... And I had to shorten the width of the indicated linking strip:
    [​IMG]
  17. jrts
    jrts Active Member
    Hi Swinger
    The whole thing just boggels the mind, fantastic detail and workmanship.
    I only dabble with the planes, watching you do this makes me want to try a few kits myself.
    Keep up the how to does and hints mate well worth watching you work.
    Best regards
    Rob
  18. Swinger
    Swinger Member
    This is a nose. The fitting is fantastic, in my case only the front element (the smallest one) was a little too large.
    [​IMG]
  19. barry
    barry Active Member
    Nose looks great I wish I could line those marks up so well.
    barry
  20. Jim Krauzlis
    Very nice work on the nose, Swinger!
    I am very impressed with the way the holes lined up so well.
    It is apparent you are enjoying this build very much, almost as much as we who are watching this thread. :D
    Jim
