repaint f-104
Discussion in 'Radio Control & Other Propulsion Methods' started by paul a, May 16, 2007.
  1. paul a
    paul a Member
    here is a repaint of mikes 104. hope you enjoy.paul
  2. paul a
    paul a Member
    and the rest
  3. paul a
    paul a Member
    it was modeled after this. a drone a couple of more details and it will be ready to model.
  4. paul a
    paul a Member
    looks like page one needs to be fixed .
  5. romfolmar
    romfolmar New Member
  6. CardStalker
    CardStalker Member
    Paul, your the best as always, thanks so much.
  7. cgutzmer
    cgutzmer Guest
    Great work! Its the kind of inspiration I am looking for right now :) What app did you use?
    Chris
  8. paul a
    paul a Member
    not the best just try hard.
  9. paul a
    paul a Member
    used the pdf creator to change it to a bitmap. then color it in with ms paint.had to go over some lines to fill in the holes.have to do the tail number on page one again forgot when you flip it, it mirrors the image.want to put some more details in.number on the side of the fuselage.want to make the us air force larger on the fuselage.things like that .just playing around to get a feel for things.good luck on yours.paul
  10. paul a
    paul a Member
    here are the pages i changed.the rest are the same.
  11. paul a
    paul a Member
    had some orange paper around. so i went no computer.you can go with or with out.
  12. paul a
    paul a Member
    i would go flying but it has rained here 3 days in a row.paper and water and aircraft don,t mix.
  13. paul a
    paul a Member
    taking a vacation back in a couple weeks.paul
