PDF parts
Discussion in 'General Card Modeling' started by cardmodeler, Apr 13, 2007.
  1. cardmodeler
    cardmodeler Member
    I have a kit that is in PDF format and I need to duplicate some botched parts. Is it possible to print only a portion of a page? I hate to waste expensive ink on parts I don't need. Any help would be much appreciated.
  2. cardmodeler
    cardmodeler Member
  3. MOS95B
    MOS95B Member
    Do you have Adobe Photoshop or any other Adobe programs? Photoshop will open and allow PDF editing (as an image, not text.)
  4. MOS95B
    MOS95B Member
  5. thewoodengraver
    thewoodengraver Active Member
    Or try pdf995. It is a free (nagware) printer driver which converts to image.
  6. thewoodengraver
  7. cardmodeler
    cardmodeler Member
    Yes, I have Photoshop Elements, I believe it's called. I will give that a try. Thanks a lot for the help>:)
  8. cardmodeler
    cardmodeler Member
  9. MOS95B
    MOS95B Member
    Elements is what I have on my laptop. She'll git-r-done for ya!!!
  10. MOS95B
    MOS95B Member
  11. B-Manic
    B-Manic Peripheral Visionary
    Acrobat reader can print ' current view '. Use the magnify tool to select the part(s) you want to print. From the file menu select 'print'. In the print dialog box select 'Current View' and 'Print Scaling' to none.
  12. B-Manic
  13. sdk2knbk
    sdk2knbk Guest
    Another method is to use the snapshot tool to draw a box around the item(s) you want to print. Reader will say "copied to clipboard". Select print, and there will be a "selected graphic" option. This prints at 100% no matter what scale you have the view zoomed to. Note that this doesn't work if selecting graphics is not allowed in the pdf properties (like in a Trotskiy file), then you have to use the current view method B-Maniac described.
    Scott K.
  14. sdk2knbk
    sdk2knbk Guest
    Scott K.
  15. catalin
    catalin Member
    there is a program: PDF Editor. i have 2.4 version. it's really good. you delete, aply stickers, colors, etc.. it's about all that keeps to pdf editing.
    catalin
  16. catalin
    catalin Member
    catalin
