Paper to Plastic Klingon D-7
Discussion in 'Extended Mediums' started by CJTK1701, Jan 22, 2008.
  1. CJTK1701
    CJTK1701 Banned
    Here we go, another in the series of "Paper to Plastic" how to threads , on how to take your favorite paper models and turn them into fiberglass, resin, or plastic models! Whoot!
    I'm going to start this off by going back to the original examples, before the model was crushed. I will however be starting a brand new model using the very same techniques.
    There are two primary ways that I do this and often I use both methods to check the other. The first is to trace out parts from an existing model and resize to my favorite size and start working out the construction. The second is to actually scan the parts of the model and resize them in photoshop, print up templates and start working out the construction. There is a third way, which is how I started the Enterprise and that's to use available blueprints to create some of the parts and use a paper model, if one exists to work out some of the compound curves. Of course if there are no prints and there is no paper model, or existing *accurate* model to trace parts from, you have to go by what is available and work these things up yourself. This, it seems, it what a lot of guys do around here. Take what is available and work it up as best you can.
    Any way, here are some of the shots of the original work up.
    Scanning method....
    http://i45.photobucket.com/albums/f63/6242amu/AK1F.jpg
    http://i45.photobucket.com/albums/f63/6242amu/AK2Fboom.jpg
    http://i45.photobucket.com/albums/f63/6242amu/AK2Fbridge.jpg
    Tracing original parts and making templates...
    http://i45.photobucket.com/albums/f63/6242amu/AKwork1.jpg
    http://i45.photobucket.com/albums/f63/6242amu/AKwork2.jpg
    http://i45.photobucket.com/albums/f63/6242amu/AKwork3.jpg
    Preliminary assembly.
    [​IMG]
    [​IMG]
    As you can see, the primary hull is almost an exact duplicate of the original only larger.
  2. saiyagohan
    saiyagohan New Member
    How about a Progress Report Joe, This also looks promissing. :thumb:
  3. CJTK1701
    CJTK1701 Banned
    I've been concentrating on the TOS Enterprise and the ROM BOP as well as other things.
    Got behind in real life stuff and had to give my house and wife some attention, not to mention the car and the truck..... it never ends.:confused:
  4. OylPslyk
    OylPslyk Aspiring Usurper
    well I'll be damned! its a "remote" control D7! :mrgreen:
  5. CJTK1701
    CJTK1701 Banned
    Uh no, that's my cordless phone. :)
  6. saiyagohan
    Don't feel bad I know the feeling. Keep On Trekkin:thumb:
  7. OylPslyk
    well, in that case: (in that sultry computer voice) = Sub-Space Communications Are Now Online.
    sign1
  8. CJTK1701
    CJTK1701 Banned
    Oh, New Hura, you naughty vixen.sign1
  9. CJTK1701
    CJTK1701 Banned
    Safety notice. Please follow the recommendations in this thread.http://forum.zealot.com/t150874/
    I never really experience much trouble with the expanding foam and used it mainly outside, or in a well ventilated area, but just to be on the safe side, please follow along with that thread. Also, there is no need to use to much foam and over do it, the foam will expand nicely.
  10. saiyagohan
    Updates on This?
  11. CJTK1701
    CJTK1701 Banned
    There will be very soon! I'm going full speed ahead on this ASAP! I want to make sure that everyone can see how easy things can be and that they can do it themselves. I've just received one of the published Star Trek Paper Model books and will show some pictures. It's obvious from looking at this publication that well meaning fans can do a lot better job than the PRO-FESH-EE-ON-ALS when they put their mind to it. The paper models here are light years beyond this simple model.
    It just goes to show what a man can do when he sets his mind to a mission and refuses to lay down.
  12. Soaring
    Soaring Guest
    Hmm, I have one question! What materials do you use for making the plastic touch? I know plastic is the obvious answer...but isn't there another material that easy to find?
  13. CJTK1701
    CJTK1701 Banned
    Fiberglass. :thumb:
  14. Soaring
    Soaring Guest
    Hmmm, can I get it at basically any hobbies and crafts store?
  15. CJTK1701
    CJTK1701 Banned
    You can get it at any WalMart, Home Depot, Auto Parts store, Boat and Motor facility, or online. I'll do another tutorial on the application and provide a list of links of Supplies, Services and Resources available to the modeler.
    It's a simple process, but must be used in a well ventilated space. Like anything else it takes a little trial and error and a little work to get comfortable with. There's also Polyester resin, or Bondo which is also readily available.:thumb:
    Again, there are certain precautions that must be observed, but most of those are listed on the label. It really is a no brainer.:mrgreen:
