Oberursel U1
Discussion in 'Gallery & Designs' started by Richard, Jun 12, 2006.
  1. Richard
    Richard Member
    Hello everyone,
    at the moment I'm building a pair of Fokker E.III models but I'm not very satisfied with the engine that comes with the model.
    Does anyone have a good drawing, preferably with measurements, of the Oberursel U1 rotary engine so I can design my own?
    Thanks in advance
    Richard
  2. Richard
    Richard Member
    Hello everyone,
    Thanks in advance
    Richard
  3. Texman
    Texman Guest
  4. Texman
    Texman Guest
  5. Gil
    Gil Active Member
    Oberursel U1 Drawings
    Hi Richard,
    Least I can do is provide you with a drawing in return for the nicely designed Clerget that I downloaded from your site. Thank you! Here is a somewhat imprecise but dimensioned drawing of the U1. Hope this enough to get you started.
    -Gil
    [​IMG]
  6. Gil
    Gil Active Member
    Hi Richard,
    -Gil
    [​IMG]
  7. Richard
    Richard Member
    Gil and Texman,
    thanks a lot for the drawing and the pics, these are a great help!
    Richard
  8. Richard
    Richard Member
    Gil and Texman,
    Richard
  9. Gil
    Gil Active Member
    AEHS Website
    Hi Richard,
    Glad you liked it. The following site is recommended for anyone who has an interest in avaiation engines:
    http://www.enginehistory.org/
    -Gil
  10. Gil
    Gil Active Member
    AEHS Website
    Hi Richard,
    -Gil
  11. Richard
    Richard Member
    first build pictures
    here are a couple of pictures of the first build of the Oberursel engine.
    http://home.planet.nl/~schul923/new/urs01.jpg
    http://home.planet.nl/~schul923/new/urs02.jpg
    http://home.planet.nl/~schul923/new/urs03.jpg
    http://home.planet.nl/~schul923/new/urs04.jpg
    As Gil said that the drawing he posted was inaccurate, I went looking on my old pc for some decent photographs that could help me.
    Much to my surprise I found a drawing that seemed pretty accurate and used this to design the engine, guess it came out quite well.
    comments please.........:)
    Richard
  12. Richard
    Richard Member
    Richard
  13. Gil
    Gil Active Member
    Beautiful!
    Hi Richard,
    Very nice! Printing on aluminized stock will do wonders for the "metallic" look of the engine.
    On the earlier posted drawing, not that it makes any difference now, I meant that the drawing was not to scale. The measurements are accurate as far as I can tell.
    Best, -Gil
  14. Gil
    Gil Active Member
    Beautiful!
    Hi Richard,
    Best, -Gil
  15. Richard
    Richard Member
    Gil,
    I'll see if I can find some aluminized stock and give it a try.
    The measurementss your the drawing were ok, without them I probably would have had to build two or three models to get the scale right. In the other drawing were no dimensions at all, can't even remember where I got it from.
    Richard
  16. Richard
    Richard Member
    Gil,
    Richard
  17. Richard
    Richard Member
    one more picture of the engine, now under the Fokker engine cover; snug fit and there's even a bit of space left.
    http://home.planet.nl/~schul923/new/urs05.jpg
    Have to shorten the rear part of the engine because of the 1mm cardboard of the firewall.........back to the drawing board..:)
    Richard
  18. Richard
    Richard Member
    Richard
  19. Gil
    Gil Active Member
    Some other work...,
    Richard,
    Nicely done! I've been working on WWI style cowls off and on for several years now. Current work centers around aluminum/paper composite construction. The image shows a U1 in a Nieuport style cowl. It still needs work (as always). Think I'll try a single piece form next. And in case you're wondering whether the composite works like real aluminum metal, rest assured it does very nicely...,
    -Gil
    [​IMG]
  20. Gil
    Gil Active Member
    Some other work...,
    Richard,
    -Gil
    [​IMG]
