nose cones
Discussion in 'North America' started by refitz, Aug 22, 2006.
  1. refitz
    refitz New Member
    I'm working on some planes and having trouble getting the nose cones to come out right. any ideas:confused:
  2. cgutzmer
    cgutzmer Guest
    What is wrong with them? ;)
  3. refitz
    refitz New Member
    they are not right i havean inner and outer. the outer is not covering the inner like it should.i'm having trouble rolling them also
  4. cgutzmer
    cgutzmer Guest
    Why does your nose cone have an inner? All the ones I have done have been a series of strips joined by strips on the inside gradually coming to a point. Can you post a pic or two?
  5. refitz
    refitz New Member
    i HAVE A PHOTO BUT DON'T KNOW HOW TO POST IT
  6. cgutzmer
    cgutzmer Guest
    :) lots of people have problems with that the first time :) you cant use teh quick reply. You click the reply button then you will get the editor with more options. Towards teh bottom of that page there is a spot called manage attachments. Hope that helps :)
    Chris
  7. rmks2000
    rmks2000 Member
    Refitz,
    When you reply to a post, there is an 'additional options' section below the comment area. You'll have to scroll down to see it. Click on 'manage attachments' and it will tell you the types and sizes of files you can upload. There will be a typical browse button to search for your file to upload.
  8. refitz
    refitz New Member
    Hope This Works
  9. refitz
    refitz New Member
    Does That Help
  10. Kevin G
    Kevin G Member
    Not sure why you are using an inner cone but just from a quick glance it appears that they are both the same size. Maybe make the inner one a bit smaller and then it will fit inside of the outer one.
  11. refitz
    refitz New Member
    Nose Cone
    ok I'll try it thanks
  12. cgutzmer
    cgutzmer Guest
    I would just try leaving it out all together unless it is for something specific to the model.
  13. rmks2000
    rmks2000 Member
    Refitz,
    FlyNThings models use tabs and slots for their models, but the nose cone tabs (S,P) are totally unnecessary. I'd cut them off. Then simply curl the cone. I built the Zero but don't believe that there were tabs on the nose. You could also skip the inner cone (unless you plan on flying the plane a lot and need a really sturdy cone for crashes).
  14. refitz
    refitz New Member
    I had planed on trying just one thanks
  15. hpept
    hpept Member
    refitz,
    unless you are willing to build a flying model, i suggest to simply trash the inner cone and use only the outer "cosmethic" cone. i was going to suggest to cut the apex of the cone a little in a circular fashion to facilitate rolling of the point and avoid tip overlap, but i see that the model is already in this way.
  16. refitz
    refitz New Member
    thats what i'm going to do use just one
