New Generic Base For Your Models
Discussion in 'Internet Finds' started by PixelOz, May 3, 2009.
  1. PixelOz
    PixelOz New Member
    English
    I took the base I designed for the Ford Hot Rod car and created a new generic base with it for other people's models. I though that some models particularly characters not always have the best balance and even if they do it's a problem with the wind because paper models are so light so I decided to do these display bases so you can glue your model to one for more stability, put it on top of it for looks or both. Like I said I also did it for aesthetic reasons, some models look very good on a display base. I created it in several solid colors and also with wood textures in two different shades and two slightly different metallic panel textures. I also designed them in the same size as the Ford model but also included a redesigned one at 50% percent size that's easier to assemble. In addition to this I included a small table that gives you an idea of what measures you are going to get if you adjust the size of the base with the percent adjustment of your printer drivers so you can print them in many sizes easily.
    You can download it at the same location were you can download the Ford car, just scroll to the bottom:
    http://www.jleslie48.com/gallery_models_other.html
    Español
    Tomé el modelo de la base que diseñé para el carro Ford "Hot Rod" y creé una nueva base genérica para los modelos de otras personas. Pensé que algunos modelos, en particular los modelos de personajes no siempre tienen el mejor balance y aun cuando lo tienen es un problema con el viento porque los modelos de papel son muy ligeros así que decidí diseñar estas bases para que pueda pegar (encolar) su modelo a una de ellas para más estabilidad o para ponerlo sobre ella para que se vea más bonito o para ambas cosas. Como mencioné, también lo hice por razones estéticas, algunos modelos se ven muy bien sobre una base. La creé en varios colores sólidos y también con texturas de madera con dos tonos de madera diferentes y dos texturas de paneles metálicos algo diferentes. También las diseñé en el mismo tamaño que la del carro Ford pero incluí una rediseñada a la mitad del tamaño (a 50%) que es más fácil de ensamblar que la grande. En adición a esto también incluí una pequeña tabla que le dará una idea de que medidas va a obtener si ajusta el tamaño de estas bases utilizando el ajuste por porcentaje de su programa de impresora así que puede imprimirlas en muchos tamaños fácilmente.
    Puede descargarla en el mismo lugar en donde puede descargar el carro Ford, solo vaya hasta el fondo de la página:
  2. PixelOz
    PixelOz New Member
    A Few Pictures Of The Files
    Here are a few partial pictures of the files so you get a better idea of what I did.
    Aquí coloco unas pocas imágenes parciales de los archivos para que tengan una idea más clara de lo que hice.
  3. bf109
    bf109 Member
    THANKS !! great job this is very usefull :thumb:
  4. THE DC
    THE DC Member
    Great Idea...
    Thanks much for these! What a great idea and awesome addition to displaying work.
    You jumped the shark, hit it in the nose, and called it Bessie!:p
    Slante,
    The DC
  5. clif52
    clif52 Banned
    Thanks for the work on the bases. I really like the metal scifi one.
