Myasischev M-4 "Atlant" by Nobi
Discussion in 'Aircraft & Aviation' started by jrts, Nov 16, 2004.
  1. jrts
    jrts Active Member
    Hi all
    Yet another :roll:
    Thought I would hit this next while waitng for parts on the Ki-61 to dry.
    This has nine pages of parts and formers, also siix pages of diagrams.
    For one of Nobi's models this is a big bird :D
    There is no point in going in to design ect as we all know Nobi's stuff by now!!
    Here we go.
    I started with the main tank it carries, not much done tonight so just the one photo :oops:
    More tomorrow
    Rob
  2. jrts
    jrts Active Member
    Hi all
    Just some photos of the main tank construction to date
    More later
    Rob
  3. jrts
    jrts Active Member
    Hi all
    A bit more done
    Finished the main tank this will be put away safe now until time comes to fix it to the plane.
    Also started the main body of the plane as well.
    More tomorrow
    Rob
  4. Leif Oh
    Leif Oh Member
    Those are nice cylinders! What an extremely good fit. Will you try to lose the black lines, same as you did on the Hawker, if I remember correctly, with liquid paper? - L.
  5. jrts
    jrts Active Member
    Hi Leif
    The fit on this thing if you cut it out right is great, no problems at all.
    What I will do with the black lines on the cylinders is wait now until I have done the rest of the model just incase I have to do more on other parts.
    I will then try to paint out the lines, using another print of this bit to test out the paints first.
    I only used the liquid paper (White out) as I had no white paint left, one of those times when you look around and think what can I use.
    The canopy of the Tempest was also done with liquid paper with a small amout of paint in it to colour it. I think it worked out alright!!
    If when it has been painted the lines show then out will come the liquid paper again :lol:
    More of the build tonight
    Rob
  6. jrts
    jrts Active Member
    Hi all
    A bit more done tonight.
    Built up the wing ribs and spars and fitted the to the planes main body.
    I did this now just in case I needed to get my porky fingers inside to aid the fit.
    After this I started the wings to do a test fit to make shure the spar was in the right place, well it was.
    Next the engines and wing tips, then these can be put to one side while I finish the main body of the plane.
    I will try to post a little more later.
    Well back to the build
    Rob
  7. barry
    barry Active Member
    Rob
    How big is this one please, you could almost convert it to a Horten. Crisp and clean as ever
    barry
  8. jrts
    jrts Active Member
    Second and last bit for tonight, OK you can stop cheering now!!! :lol:
    Fitted the first engine, the other are not dry enough to fit.
    As I hate hanging around for glue to dry I fitted another section of the body and started the tail fins.
    More tomorrow night
    Rob
  9. silverw
    silverw Member
    OK, Rob, I'll hold back the cheering...but only for a short time!
    Time's up!
    Yaaa....Wa Hoooo! Nice stuff! :lol:
  10. jrts
    jrts Active Member
    Hi all
    Thanks for the kind words guys
    The model is about 35cm in length and has a wing span of 40 cm, its big!!
    I have a Horten 229B night fighter in 1/33 by Fly Model, I might have a go at that next.
    More tonight
    Rob
  11. jrts
    jrts Active Member
    Hi all
    Done a little more card bashing tonight!!
    Finished the engines, added a few more body sections and done a bit more on the tail fins.
    More tomorrow night
    Rob
  12. barry
    barry Active Member
    Hi Rob
    If it's that big maybe we could con NOBI into doing a "Bear"
    barry
  13. Ashrunner
    Ashrunner Member
    Definitely try!!!!! I have "mentioned" it to him on a number of occasions! hehehe
  14. NOBI
    NOBI Active Member
    Hi There,
    very great build. i really enjoy to see another people build my model...thank you very much to share those pictures to us
    Ahh yes, Russian aircraft r subject i interest because it wired...but i must think and think and think and think before design russian subject because very small support for this M-4 Atlant when it release :D
    Bear is my favorite too
  15. jrts
    jrts Active Member
    Hi Nobi
    The design on this bird is great mate and it all fits very well :D
    If not a Bear how about a FW 200 Condor-6 of KG 40 With Hs anti-ship missiles :D :D
    Or a Do 18
    I would buy any of the three (third being the Bear)
    Rob
  16. Jim Krauzlis
    Jim Krauzlis Active Member
    I would buy the Bear in half of a heart beat!
    Cheers!
    Jim
  17. barry
    barry Active Member
    NOBI
    how many Bears would you have to sell to make it worthwhile doing ?
    barry
  18. jrts
    jrts Active Member
    Hi all
    Almost finished the body of the plane, one tail section and then the end caps to do.
    After this I will glue on the wings, I have also just started the whells so I hope to get them fitted tonight.
    With luck I will have this done tomorrow :roll:
    If any of you are going to build this (I would, I intend to build it again)
    A little tip would be, when you cut out the body sections of both the plane and tank cut just inside of the heavy black lines. This will remove the problem of the black joint lines (my fault not the design). I should have done this when I first cut the parts out :oops:
    More later
    Rob
    PS Barry I think it would have to be about 40 to 50 units to start with, more would be better :roll:
  19. jrts
    jrts Active Member
    Back again
    Last bit for tonight
    Finished the nose section.
    More tomorrow
    Rob
  20. Jim Krauzlis
    Really coming out great, Rob...I don't mind those lines, sort of looks like panel lines to me. :D
    What is the printed color of this beauty...white or light gray?
    Just a thought, but a model of the Bear would be awesome printed out on metallic silver paper! I know I saw some experiments in printing with laminated aluminum but there might be someone who has a better source for metallic paper that would fit the bill. :wink:
    Something about that bright red star on a shiney metallic surface, rather striking, I think.
    I don't recall coming across ANY model of the Bear anywhere else...so it would have the unique factor of being the only one out there...might help in sales, wouldn't it? What scale would it be in...I would like to see 1/33, but that might be too much but think of the detail you could have. 8)
    Might be a good idea to take a poll and see how many people would have an interest in that beauty. :idea: Can I vote ten times? :lol:
    Cheers!
    Jim
