my very first design c-47
Discussion in 'Gallery & Designs' started by yaniv, Feb 17, 2007.
  1. yaniv
    yaniv Active Member
    thank u very mach my friend i not sure yes for 100% about this tail but this is the best on for the last 3 weeks
  2. Rick Thomson
    Rick Thomson Member
    Looks pretty good to me.
  3. Willja67
    Willja67 Member
    Okay Yaniv I finally got to look at your file and I gotta tell you I'm very impressed with what you've done so far.
    Here are my suggestions for how to go about the cockpit, first off here is the way you have done the top of the nose in front of the cockpit windows:
  4. Willja67
    Willja67 Member
    The line I have highlighted in the previous post was used as the basis for the line that I have drawn in screenshot below. Most aircraft have the top of the nose extend into the cockpit and that becomes the top of the instrument panel so it would be wise to find pics of the instrument panel and look at the shape of it cause I might not have done it quite right.
  5. Willja67
    Willja67 Member
    I then lofted the line I drew in and the previously selcted line and that becomes the top of the nose. Then I use that surface to trim off the bottom of the windscreen, again compare this with the way the original looks.
  6. Willja67
    Willja67 Member
    This part might make you cry Yaniv but I know I would like to know if my model had a problem so I'm going to show you this one. Remember in my B-25 example about how the windscreen needed to be flat and not twisted? Well you got a little bit of a twist in your windscreen. I extended the line of the middle of the windscreen then copied it and lofted those 2 lines and you can see in the attatched pic that it needs a little tweaking.
  7. yaniv
    yaniv Active Member
    i just now see the problem in my nose
    thanks alot will
    i tray to fix it now (its 06:00 am)
    the result is looks more near to the source?
      File size:
      284.9 KB
      121
  8. yaniv
    yaniv Active Member
    pic 2
      File size:
      285 KB
      117
  9. kooklik
    kooklik Member
    Great ! Yaniv finally u've made it. Kepp trying and trying. I'm looking at u from under sea.
  10. yaniv
    yaniv Active Member
    hi to all
    here is a pic with the all full tail parts (i also split the surface from the mail tail) and also the full airplane view
      File size:
      511.4 KB
      112
  11. barry
    barry Active Member
    Designer Yaniv
    A brilliant result from a long hard slog'
    respect
  12. Lex
    Lex Dollmaker
    You've did it!!
  13. yaniv
    yaniv Active Member
    yes
    i did it :)
    with all of your help :)
  14. Ashrunner
    Ashrunner Member
    I've been watching this thread from the beginning yaniv. Very nice, very nice indeed.
  15. yaniv
    yaniv Active Member
    thank u very mach ashruner
    i now tray to figer how to make the rest of the tail part (its hard and i not start the wings :S)
    ps ashrunner
    u have a 3d drawings of p51b?
  16. yaniv
    yaniv Active Member
    hi to all
    i know this wing not that good its just a test for it
    i hoppe to make it more good like the source
      File size:
      396.3 KB
      127
  17. fimdan
    fimdan Member
    looking good man, When will you start printing all those pieces?
  18. yaniv
    yaniv Active Member
    ammm
    i think i start print all whan i finsh all
    no?
    i think fimdan u have more experience in design
    what u think?
  19. catalin
    catalin Member
    woo hoo... i haven't visited this link from the first page... you've made a huge progress... after you'll unfold it... it will be a very good model...
    congrats, my friend
  20. yaniv
    yaniv Active Member
    thank u very mach all :)
