my very first design c-47
Discussion in 'Gallery & Designs' started by yaniv, Feb 17, 2007.
  1. 57townsman
    57townsman Member
    That looks great, Yaniv. :grin:
    For the tail segment, what if you modeled the fuselage, tail fin and fillet as separate pieces? That way the fuselage segments would be conic sections with the last one tapering to a flat rather than a point. Keep in mind, I'm viewing this from an assembly point of view rather than a design viewpoint. I don't know if it is easier to design it as one piece then cut it up or to design as individual pieces. :oops:
    SteveK
  2. yaniv
    yaniv Active Member
    another pic of the new tail
    still cant make the last tail part
    but u think its looks ok or suld i tray somthing different?
      File size:
      395.1 KB
      166
  3. Lex
    Lex Dollmaker
    Wow, it's fantastic! You can stick to this.
  4. yaniv
    yaniv Active Member
    hi nezard
    u realy think its looks like the source?
    i still need to make the last part but not time for it yet :(
  5. fimdan
    fimdan Member
    Hey.
    I might have missed that but what is the scale of you model? Have you configured rhino to use proper units? It is much easier to work on your project when you have your model designed with proper dimensions. For example if you intend to build your model in 1:50 scale, make sure that every meter from 1:1 scale shows up as 2 cm in rhino. This way you will avoid a lot of changes that will be necessary when scaling the model down. It is very easy to be deceived by rhino when it comes to distances. For example, you may think that something is big on your screen, but when you scale it and print it you may find that your part is too small to even cut it out. Keep that in mind. Also, remember that paper is not infinitely thin (unlike the surfaces you are working with in rhino) so keep that in mind as well. May not matter with big parts but small pieces may become difficult to assemble.
    Just a word of advice,
    Good job and don't give up,
    FimDan
  6. yaniv
    yaniv Active Member
    thanks my friend
    well i think make it in 1/33 scale what i need to do in rhino to make it on 1/33
  7. fimdan
    fimdan Member
    Ok
    First think is to set model units in properties to whatever you like to work with. In my case I decided to work with centimeters (see the attached image). I strongly suggest you take a minute or two exploring properties window. It contains a lot of useful settings that you may want to adjust to your liking.
    Once you choose the right model units, you can set the background image to proper size. In my case, I scaled the background image to make the sub about 98cm long (1:100 scale). It helps to have drawings that have scale bars in them. This way you can check if you got everything set up correctly. If you work in 1:33 scale than each meter on the scale bar should equal to about 3.03 cm in rhino. 33 x 3.03 is about 100.
    This way, rhino dimensions are the same as your model's dimensions. This really helps when you have to offset curves or surfaces.
    That should get you started. Let me know if something is not clear.
    FimDan
  8. Lex
    Lex Dollmaker
    Um... Just to ask, does those scale not get lost when you export the model? And through all the reduce/fit to paper size thingys?
  9. yaniv
    yaniv Active Member
    thank u very mach fimdan :)
    i just need to figer how to make my tail :(
  10. fimdan
    fimdan Member
    Good question.
    That depends. I believe exporting from rhino is accurate enough. I export all unrolled parts to corel draw and print them from there (using ai format). When you do it that way the program asks you if you want to preserve model scale.
    Printer handling is another story that has nothing to do with making a model in rhino. If your printer does not print right, you should get one that does. This is manufacturer specific issue. My i960 from Cannon does a good job keeping dimensions right. You should always print your pages with a few scale bars so that you can easily check if your printer is messing things up.
    Yes that is always difficult. The fuselage is usually the easiest part. I got stuck on my D520 tail as well. Good luck and don't be discouraged. Take it easy. You chose a good aircraft. Don't make it too complicated.
    FimDan
  11. Lex
    Lex Dollmaker
    Yes Yaniv, give it a brainstorm and see what designs you can come up with :D
    And FimDan, I normally don't worry about scales as I normally prefer printing at some awkward precentage~ For the few that does I'll scale the parts in the drawing program instead.
  12. yaniv
    yaniv Active Member
    after all this bed news about the tail that i not found the way to make
    i have some funny news
    the 5000 viewer will got a copy or a big discount tot he model :)
  13. Bowdenja
    Bowdenja Active Member
    Looks like perseverance works Yaniv! It truely coming to gether nicely.
    One day I've got to learn that stuff (Rhino) ........... right now it's just pretty colors and lines. One day with a point of reference I'll be able to help:oops:
    john
  14. yaniv
    yaniv Active Member
    u make the colors i make the 3d work :)
  15. yaniv
    yaniv Active Member
    i need some rear side pic of the tail
    any one can help me found some?
  16. yaniv
    yaniv Active Member
    i make this today after i not found any way to progres my tail
    so some smol progres on the plane will be more practical :)
      File size:
      349.8 KB
      95
  17. cgutzmer
    cgutzmer Guest
    Lookin good there Yaniv! Good idea to go to another part. COming back later always seems to help me.
    Chris
  18. yaniv
    yaniv Active Member
    looks like we have afix tail :)
    after +- 3 weeks looks like we do it
    what u think?
      File size:
      417.6 KB
  19. yaniv
    yaniv Active Member
    what u have to say :p?
      File size:
      329.3 KB
      77
  20. paulhbell
    paulhbell Guest
    First time I've looked in for a couple of days, looks bloody good.
