my very first design c-47
Discussion in 'Gallery & Designs' started by yaniv, Feb 17, 2007.
  1. yaniv
    yaniv Active Member
    tail wheel hole
      File size:
      27.4 KB
      190
  2. yaniv
    yaniv Active Member
    front dooe back view
      File size:
      18.6 KB
      190
  3. yaniv
    yaniv Active Member
    and the last 1 for now
    full 3d
      File size:
      9.4 KB
      194
  4. Huey
    Huey Member
    Yaniv, the bird is really looking great. you've already answered your own question about the nose by incorporating it already in your design. the discussion thread about doing a C-47 by a group of members here never took off. we could not even decide on the size. at 1/33 scale, that will be a something indeed. everyone is cheering you on, you're almost there... it would really be great to see you pull this off. then maybe you can do a Kfir for your next project.
  5. Willja67
    Willja67 Member
    Yaniv,
    Looks like you're really starting to pick it up. Making it past the initial frustration is the hard part from now on it gets really exciting cause you learn things faster and everything builds on everything else.
    I hope you don't mind some constructive criticism, I have kept looking at your cockpit windows and they didn't look right to me so I went looking for images and found this one
    You have made a slight angle change on the windscreen on your model and it is incorrect. But the good news is it will simplify the design somewhat so you have fewer parts.
  6. yaniv
    yaniv Active Member
    hi huey thanks for the good word this bird never come like this without the mebers help and support
    well i dont know if i make a kfir
    my dream is to make a LAVI model but never found a cros section for this one :(
    wiil i will be more than heppy if any time u found something incorrect u will tell me about it
    i tray to figer out how to fix the windows
    i also need to found the way to make the inside parts :)
  7. yaniv
    yaniv Active Member
    after looking in the site u send me will i think i found the problem in my WIN
    but i not sure about it
    i add a drow i make in the paint and please let me know if i am right
      File size:
      6.5 KB
      219
  8. Willja67
    Willja67 Member
    Yup that's it.
  9. yaniv
    yaniv Active Member
    ok i will tray to fix it :) thanks u :)
  10. yaniv
    yaniv Active Member
    this win is ok?
      File size:
      26.8 KB
      223
  11. yaniv
    yaniv Active Member
    i not mach like the middle cut
      File size:
      29.9 KB
      227
  12. Willja67
    Willja67 Member
    The way you've flattened it looks great but take another look at the top of the nose below the windscreeen it is almost touching the window itself. You have the skin sloping down from the middle. The real thing looks like it's almost flat on top
  13. yaniv
    yaniv Active Member
    this windows are mach good no?
    or shuld i need to fix it more?
    i work on tham 4 hours
      File size:
      27 KB
      168
  14. yaniv
    yaniv Active Member
    that whas realy hard :)
      File size:
      10.1 KB
      206
  15. paulhbell
    paulhbell Guest
    I am here asking questions again. What colour scheme are you going to use, a camo version would be nice.
  16. yaniv
    yaniv Active Member
  17. Amazyah
    Amazyah Senior Member
    I know what you mean.
    I have been working on a new cube and have put in about 60 hours in it already, because I don't know the software and I am trying to figure out every move.
    60 hours and it is only a cube not a plane!
    Your plane is looking real good though, Yaniv!
    I admire your persistance! Keep on, keeping on!
    Russell
  18. Willja67
    Willja67 Member
    I've got over 2 years on my Corsair so I feel your pain. If you're truly committed to this project expect it to take awhile.
    Would you mind sending me your file? There is something that I would like to show you and it would be easier if I had the file.
    The offsetsrf command is invaluable for doing the cockpit and interior. Take a look at it and see if you can figure it out.
  19. yaniv
    yaniv Active Member
    hi will thanks for your reply
    i send u the file over the email :)
  20. yaniv
    yaniv Active Member
    hi people
    more than 3 hours its tack me to make the tail gear (orange)
      File size:
      481.3 KB
      137
