my very first design c-47
Discussion in 'Gallery & Designs' started by yaniv, Feb 17, 2007.
  1. yaniv
    yaniv Active Member
    a print preview
    also check page 20
      File size:
      290.7 KB
      221
  2. yaniv
    yaniv Active Member
    BTW
    i still not like my tail of the model
    i tray every day to make it like the real one but not resolt
  3. fimdan
    fimdan Member
    Tail is not easy. This is your first model so don't expect to get everything correct every single time. Let me assure you that you will be making changes to you model many times in the future. If you want to stick to the tail and try to fix it, go ahead. Just don't try to make this model perfect. Make it so that it makes you happy, and if you have very high expectations, I would like you to look at my post from a while ago about being a perfectionsit.
    Good job so far. Keep it that way
    FimDan
    PS One thing that opened my eyes is what some people here told me. Don't try to scale the real plane down because you will never be happy. You have to design so that the plane looks like the real one but at the same time it is easy to assemble from paper. That means changing the appearance a little, moving things here and there, not having all the parts perfectly round. Aim for simplicity.
  4. yaniv
    yaniv Active Member
    well for now its all looks more than ok for me the only problem is the tail
    and i have no ida how to make it looks like the real 1
  5. barry
    barry Active Member
    Seems a dumb question but can do the tail seperately and sink it down into the fuselage and run an autofit(blend) on it, sorry do not know the right terms
  6. paulhbell
    paulhbell Guest
    Idea.
    Yaniv.
    How about this design.
  7. yaniv
    yaniv Active Member
    i think about it also but only whan i finsh the main model
    i have a drawing of this "GEERS"
  8. paulhbell
    paulhbell Guest
    Hi Yaniv, just thought you would like the photo.
  9. yaniv
    yaniv Active Member
    very smol update
    what u say about this tail? (i knoe the last cross is to mach rounded
    i hope to found a way to fix it
    if some on can please tack alook on the old tail and on the new 1 and tell me what he think
    paul thanks for the pic :) i f u have more ida its will be great :p
      File size:
      175.1 KB
      161
      File size:
      175.1 KB
      162
  10. paulhbell
    paulhbell Guest
    I have plenty of ideas, I just wish I was good enough to help you with it.
  11. yaniv
    yaniv Active Member
    u can send me any of your ida to my emial and if u have any way to help me with tail its will be wanderfull :p
  12. jleslie48
    jleslie48 Member
    this is a great project in kit bashing.
    use this c47, and trotskiy has several seaplanes, take a pair of his pontoons,
    and enlarge them to fit the the C47, jury rig the struts and your done.
  13. yaniv
    yaniv Active Member
  14. Krzychu74
    Krzychu74 Member
    Hello yaniv!
    Good job! I observe your work from beginning.
    Kartobau.de isn`t polish forum. It is german forum. :)
    Best regards.
    Krzychu74
  15. yaniv
    yaniv Active Member
    sorry for no update for long time
    i just not have enough motivation and i need some time to relex from it
    dont wary i not forgot u :)
  16. Lex
    Lex Dollmaker
    Don't worry that's what most designers do :D
    That's why you often see a bunch of models coming out from one designer at once and then one year of silence~~
  17. yaniv
    yaniv Active Member
    ok :)
    after long time we not paly wwith this bird we back to work on it :)
    today i finsh to make the MAIN Disk's
    next step will be to unroll and print it out on A4 paper in 1/33 scale
    (at the moment i found the ida how to make it into page and all the print steps)
  18. yaniv
    yaniv Active Member
    ok :)
  19. Alcides
    Alcides Member
    Hi, Yaniv
    Nice to see your progress. Go ahead !!!
  20. Alcides
    Alcides Member
    Hi, Yaniv
