My Bell-Boeing QTR (Quad Tilt-Rotor)
Discussion in 'Aircraft & Aviation' started by rafaelgonzalez65, Dec 18, 2007.
  1. rafaelgonzalez65
    rafaelgonzalez65 New Member
    Hola!!!
    This is my last adventure. It's my take on Bell-Boeing's QTR, the current incarnation of the V-44, the V-22's biger brother. I call it the StormWind:
    Two pics of the original projected subject:
    [​IMG]
    [​IMG]
  2. rafaelgonzalez65
    Inspired on its lines, I took one unassembled AC-130 I had lying around:
    [​IMG]
    Then covered it with newspaper scraps wetted in a solution of 1 part water+2 parts white glue
    [​IMG]
    Here's what you get, hard as Vacform plastic
    [​IMG]
    The two halves together
    [​IMG]
  3. rafaelgonzalez65
    Primered for the first time:
    [​IMG]
    Then I cast the engines from a V-22 kit in plasticine molds poured with automotive boby repair resin:
    [​IMG]
    The result:
    [​IMG]
    Then made the wings from those of the V-22 kit in 1/72 and 1/48:
    [​IMG]
    [​IMG]
    Covered everything in Bondo
    [​IMG]
    And assembled the engines, with a little balsa sandwiched in, for thickness
    [​IMG]
  4. rafaelgonzalez65
    After meeting the brush, and fitting the engines and props, she looks like this:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    It was FUN!!!
    I hope you enjoy it as much as I enjoyed building it!!!
    Saludos,
    Rafa
  5. Dyna-Soar
    Dyna-Soar Member
    Very Nice! I saw it earlier on the Starship modeler forum as my alter-ego Atlantis v2.0.
