Monday Afternoon August 4, 2003 At Smiths Falls
Discussion in 'The Real Thing- North America' started by railwaybob, Aug 11, 2003.
  1. railwaybob
    railwaybob Member
    I also happened to be in Smiths Falls on the August holiday around 4pm. (It seems as if I have no choice but to be going home through Smiths Falls a lot!) I was running a bit late getting home from Brockville but decided to drop by the VIA/CP Rail station for half an hour. Two SD-40-2s (#5774 and #5587 ) were idling on the runaround track on the other side of the north main line with a string of boxcars, tankers, and hoppers headed for North Bay.
  2. railwaybob
    railwaybob Member
    Shortly after I arrived, the Toronto-bound VIA (Genesis P42 #911) pulled in from Ottawa off of the VIA Smiths Falls sub onto the south main line.
  3. railwaybob
    railwaybob Member
    This is #611 pulled into the station
  4. railwaybob
    railwaybob Member
    I expected that, as soon as they had loaded their passengers, #611 would be pulling off the south main line onto the the CPR Brockville sub. However, the signal light stayed red - with very good reason. The Ottawa-bound VIA (F40PH #6404) came around the corner about 15 minutes later
  5. railwaybob
    railwaybob Member
    As soon as #6404 cleared the switch, the signal turned green over red for #611 to head down the CPR Brockville sub.
  6. railwaybob
    railwaybob Member
    And #6404 kept on going, switched north onto the VIA Smiths Falls sub around the corner and carried on to Ottawa.
  7. railwaybob
    railwaybob Member
    But the action didn't end there. No sooner had the VIA #6404 disappeared around the corner to the north, when SD40-2 #5774 and #5587 uncoupled from their train, proceeded west, switched over to the north main line, then to the south main line and stayed at the far western end of the line.
  8. railwaybob
    railwaybob Member
    Behind the strings of freight cars in the yards in front of me, I heard the sound of two locos starting up. A string of about 12 freight cars were being pushed out of the yard by two GP9s (#8231 and #8220), westwards towards the two SD40s. The freight moved out of the yard onto the north main line.
  9. railwaybob
    railwaybob Member
    The two GP9s then moved back east on the north main towards the station and stopped- right in front of me.
  10. railwaybob
    railwaybob Member
    Another shot
  11. railwaybob
    railwaybob Member
    Then the two SD40s came back from the west end on the south main and stopped. #5587 was low on water and had to be refilled. So, here I had two GP9s (#8231 and #8220) on the north main and two SD40-2s (#5774 and #5587) on the south main.
  12. railwaybob
    railwaybob Member
    As I moved to the SD40-2s, the two GP9s started to move down the line, crossed over to the south main and onto the Brockville sub chasing the tail end of VIA #611- maybe delivering cars to the industries down in Brockville or perhaps for an interchange with CN?
  13. railwaybob
    railwaybob Member
    And out onto the Brockville sub
  14. railwaybob
    railwaybob Member
    Oops, it was 6:30 pm and I was long overdue home. How time flies when you're watching the trains.
  15. Clerk
    Clerk Active Member
    Nice groupe of shots Railwaybob. It sure paid off for your stop.
