Model Of The Month: Skyrim - Frost Dragon
Discussion in 'Gaming & Toys' started by daishi, Feb 6, 2012.
  1. Zathros
    Zathros Guest
    That is one of the best Dragons I've seen!! I hope you don't mind that I linked the photo, it is too good to pass up!:thumb:
    [​IMG]
  2. anthony344
    anthony344 Member
    ditto to that.:thumb:
  3. daishi
    daishi Member
    Thx!
    Bethesda makes great models, it was just luck they used the frost dragon with this pose as a loading screen (i think frost dragons look the best in skyrim, and this pose is simply awesome).
    Ofc i dont mind i generally use links cuz direct linked pictures are usually frowned at at forums. make the server load bigger or something like that.
    Image links are usually preferred cuz forum servers dont suffer, and using the Text to Image plugin for Firefox make it look the same.
  4. Zathros
    Zathros Guest
    You can upload the images or link them. That's why the "buttons" are there! To be honest, I prefer posts with pictures. People will click on a link or two, but if the pictures are right in front of them, they will take the time to look at them. it also saves the person reading the thread a lot of time. :)
  5. daishi
    daishi Member
    Ok. I'll do that in the future if I remember (old habits die hard).
    BTW If you use Text to image plugin u don't have to click. If the text link points to an image directly, it switches it to the actual image in the browser. (and its on client side so doesn't put extra load on the servers)
  6. anthony344
    anthony344 Member
    Hiya daishi
    What is the Frost Dragon size going to be finishing at.
  7. clif52
    clif52 Banned
    I love the look of this dragon. I wonder if you finished the build and sealed it with a acrylic clear if you could airbrush clears over it to get a metallic effect or a multicolor irredesent (nor sure on that spelling) color change effect? I've been retired from airbrushing for almost 20 years now but I'm starting to use it again for my models and custom toys. I really would love to build one of these if you release a model version to the group.
    Clif
  8. daishi
    daishi Member
    I genrally only use a matt fixer spray so the paint wont run if it gets a little wet by accident.
    I generally keep my models matt, because glossiness would show some of the imperfections and the wavyness of some glued edges (thx to the flaps and the uneven bends they cause after gluing). Its not a big issue with this model because the high poly base im working from, but it would show with my WH40k models for example.
    I dont say it'd look bad with glossy surfaces, its just my preference.
    the dragon is 500mm wide and around 700mm tall (still need to unfold the rock it'll stand on so it may be a little more)
    Worked on it most of this weekend so about half of the tail and the behind pars under the hips are missing only (and the rock). depending on my job, i imagine i can release it this weekend (if nothing happens)
  9. anthony344
    anthony344 Member
    That's a great perfect size:thumb: , & also matte paper is also best choice for less colour wear & bring out the model more. As for gloss paper well very bad colour wear if it direct contact with light & if you are handling with the model it gets fingermarks all over it. well that's my experience what i learn't maybe other builders got different opinion in what photo paper to use.:rolleyes::p
  10. sidewinder81777
    sidewinder81777 Midnight Modeler
    I love this, I'm so going to build one
  11. bf109
    bf109 Member
    that really looks great and a clean build !!
  12. daishi
    daishi Member
    Another update:
    Only the lower half of the tail and the rock is missing now.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  13. Zathros
    Zathros Guest
    WHOA!That is incredible!! :eek:
  14. anthony344
    anthony344 Member
    It looks sooo real:-o:-o , Incredible work daishi & you have to be proud of your self after all that hard work on editing from that mesh.Totally great job.:thumb:
  15. Zathros
    Zathros Guest
    Well if that isn't a motivator, then I don't know what is! Congratulations Daishi! :)
  16. vbsargent
    vbsargent Member
    Very well deserved congratulations!
  17. daishi
    daishi Member
    Thx!
    BTW just finishing up the tail, looks really good, Ill make the rock this weekend and release the templates.
  18. Zathros
    Zathros Guest
    Fantastic, every aspect, just simply fantastic! :)
  19. Activate
    Activate New Member
    Dear god. I want to build this so badly.
  20. daishi
    daishi Member
    Then you're in luck Ive finished with the prototype without any major problems so I'll make some minor tweeks tomorrow and upload the templates.
    BTW Ive sot some pics:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
