Mirage III scale up
Discussion in 'Aircraft & Aviation' started by mor54, Aug 26, 2007.
  1. loadmat
    loadmat Member
    Awewsome job on the canopy - I have several to do. What did you use to make the mold/ Was it wall spackle?
    Thanks
    Loadmat
  2. mor54
    mor54 Member
    Hi Loadmat,
    Sorry for the late responce.
    I am using white cast that is used to fille cracks in walls. Name is in Hebrow, so it whant help you.
    Shalom Mor
  3. loadmat
    loadmat Member
    Mor -
    Yes - I believe it's wall spackle/filler. Thank you for the response - I really enjoy your build. I am building a Turan 4 out of a T-54 in 1:25. Thanks Again.
    Shalom
    Loadmat
  4. mor54
    mor54 Member
    Loadmat,
    Tiran 4 is an Israeli version of the Russian T-54, any special reason ?
    Shalom Mor
  5. loadmat
    loadmat Member
    Mor,
    I have built IDF armor models in plastic of the M-50/51, Ti-67, M-60 and Merkava. Now that I work in paper, I thought it would be interesting to convert a T-54 to a Turan 4. Another project I have in mind is the Kfir. I would also like to do an IDF Phantom, (I used to work on the F-4G Wild Weasel) and the IDF Republic SeaBee.
    Shalom
    Loadmat
  6. mor54
    mor54 Member
    Loadmat,
    If you need any information (pictures, profiles) on IDF aircraft, just send me a message.
    Shalom Mor
  7. mor54
    mor54 Member
    Hi all,
    The canopy is done, but not finished. After a very long matching process with the canopy, of bonding and removing it for small adaptations, I was hapy with results.
    [​IMG][/IMG]
    But than, I compared it to the profile drawing, and fined out that the canopy shape near the wind screen is wrong, think the mistake was in the mokd itself.
    [​IMG][/IMG]
    So, I am going back to the drawing board.
    Shalom Mor
  8. Lex
    Lex Dollmaker
    You did a fine job on the canopy :)
  9. mor54
    mor54 Member
    Hi all,
    Doing some painting touch-up, between one thing and another. A chalange that I didn't solve up to now is how to do the slogan "mirage iiic", and some other like "no step" and "snecma atar" in french.
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    Next step will be the assembly of the fuel tanks.
    Shalom Mor
  10. mor54
    mor54 Member
    Hi,
    The fuel tanks are assembled, and part of the writing - "snecma atar 9" and "no step" in french are done. For the writing, I used what is known here as "Letra Set", with letter size of 2.5mm (see last picture). By "writing" on the letters, it adher to the model. Still need to fined a solution for the "mirage iiic".
    I belive that pictures are better than words, so her are the pictures.
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    Shalom Mor
  11. mor54
    mor54 Member
    Hi every one,
    The model is done and finished !!!
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    The "mirage iiic" was the last problem I was "stuk on", an internet search to find this label at 1-32 scale, didn't gave any results. So the last solution was to hand kopy it, with a kopy paper, by hand writing it on both sides. To it I added two symboles for shot down aircraft.
    [​IMG][/IMG]
    And some more pictures ....
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    Today, Mirage 758 under number "158", is at the Israeli Air Force museum, and together with another mirage - 159 / 759, is holding the record for 13 (each) shout down aircraft (picture taken from airliners.net).
    [​IMG][/IMG]
    Thanks to you all, this thread was a great pleasure for me, and at the moment I am working on the next thread - this time a warship.
    So, till next thread
    Shalom Mor
  12. Jan Kytop
    Jan Kytop Member
    Very good work.
    Please notice,it is: ne pas marcher and not ne pass marcher,
    one s only.
  13. Rick Thomson
    Rick Thomson Member
    Very nice model.
    I am curious though as to why the no step stencils would be in french on an Isreali A/C?
