I've been working recently on some tiny projects I can do at my desk in the house, while dull stuff is on TV...
First, I saw a commercial DPM add-on of an access door on to the roof, which looked like a good bit of roofing detail (although it appeared a bit rough). So, working on 2mm to 1foot (which I find easier than thousands of an inch)...
Seven feet high equates to 14mm, so cut two 14mm squares of thin styrene, chop off the corners and glue them to the side, getting this:
A bit of offcut wood for the door, and some laser printer labels cut into strips and stuck on the side for battens, then a whack of brown paint. I think I'll put corrugated iron on the roof section before weathering it...
Charles
Charles
