Messerschmitt Bf 109 F-4 - Step by step...
Discussion in 'Aircraft & Aviation' started by korvette, Nov 13, 2006.
  1. korvette
    korvette Member
    Cut out the parts carefully (advantage: the tape secure the fragile construction) and remove the protective film of the tape. Than press the outer frame on the overhead transparency. That´s it and most important: without any glue.
      File size:
      147.3 KB
      255
  2. korvette
    korvette Member
    Then the same handling for the inner frame. It´s a little bit tricky to place it in the right place. Take care for it and you can adjust a little bit with a needle.
      File size:
      163.1 KB
      199
  3. korvette
    korvette Member
    Now you have to form the parts and glue where necessary. Some recolouring will be done after assembling to the plane. The windows will then be cleaned with Q-Tips and desinfection fluid. Meanwhile I sprayed UV-Protection on the modell...
      File size:
      135.5 KB
      211
  4. Alcides
    Alcides Member
    Wow!!! I's a pleasure to follow this thread.
    Thanks for sharing tips and the photos.
    Regards
    Alcides
  5. cardmodeler
    cardmodeler Member
    Yes, this has been a treat for me to watch this model come together. Quite an inspiration! Can't wait to see the finished product!
  6. cgutzmer
    cgutzmer Guest
    Sticky tape! great idea! I had heard it mentioned it before but your pics really brought it together for me - thanks!
    Chris
  7. korvette
    korvette Member
    Thanks again for having a look on this thread.:)
    Now we can put the single parts in their right position...
      File size:
      137.9 KB
      142
  8. korvette
    korvette Member
    front part...
      File size:
      129.5 KB
      150
  9. korvette
    korvette Member
    ...added some small support elements for the frame.
      File size:
      115.1 KB
      145
  10. korvette
    korvette Member
    Cockpit II
    Parts: 11 / 476
      File size:
      111.6 KB
      194
  11. korvette
    korvette Member
    ...preperation works...
      File size:
      158 KB
      196
  12. korvette
    korvette Member
    ...assembling of the inner parts...
      File size:
      117.2 KB
      190
  13. korvette
    korvette Member
    ...and finally we have a result.
      File size:
      160.5 KB
      193
  14. korvette
    korvette Member
    Landing gear I
    Parts: 22 / 498
      File size:
      168.7 KB
      195
  15. korvette
    korvette Member
    building process...
      File size:
      165.4 KB
      146
  16. korvette
    korvette Member
    two "legs" ready...
      File size:
      148.3 KB
      142
  17. korvette
    korvette Member
    Wheels
    Parts: 40 / 538
      File size:
      188.7 KB
      149
  18. korvette
    korvette Member
    a lot of work to do, but not very difficult, if you have some drill tool for forming the wheels.
      File size:
      139.5 KB
      202
  19. korvette
    korvette Member
    and here we have two wheels. Some more colour will be added after final assembling.
      File size:
      103.2 KB
      200
  20. korvette
    korvette Member
    landing gear II
    Parts: 10 / 548
      File size:
      182.8 KB
      142
