Messerschmitt Bf 109 F-4 - Step by step...
Discussion in 'Aircraft & Aviation' started by korvette, Nov 13, 2006.
  1. korvette
    korvette Member
    Step 2
      File size:
      117.5 KB
      232
  2. korvette
    korvette Member
    Now we can start to install the whole construction...
      File size:
      136 KB
      297
  3. korvette
    korvette Member
    First to finish the lower side...
      File size:
      134.7 KB
      237
  4. korvette
    korvette Member
    ...and at last the upper parts.
      File size:
      158.9 KB
      240
  5. korvette
    korvette Member
    Middle section Flaps
    Parts: 12 / 384
      File size:
      141.6 KB
      238
  6. korvette
    korvette Member
    ...construction...
      File size:
      151.5 KB
      229
  7. korvette
    korvette Member
    ...ready to install...
      File size:
      137.2 KB
      238
  8. korvette
    korvette Member
    ...result !
      File size:
      163.5 KB
      230
  9. cgutzmer
    cgutzmer Guest
    That is coming together really great! Excellent work - I really like the weathering built into the color of the model. You are doing an excellent job on those details - keep em coming for us! :)
    Chris
  10. korvette
    korvette Member
    Thank you Chris, I will do my very best...
    Outer Flaps
    Parts: 16 / 400
      File size:
      135.4 KB
      229
  11. korvette
    korvette Member
    Ready....
      File size:
      132.7 KB
      259
  12. korvette
    korvette Member
    ...steady...
      File size:
      125.1 KB
      210
  13. korvette
    korvette Member
    ...GO ! Wings are finished.
      File size:
      171.2 KB
      209
  14. korvette
    korvette Member
    Oil cooler / Hoods
    Parts: 12 / 412
      File size:
      141.1 KB
      238
  15. korvette
    korvette Member
    ...necessary preperation works for assembling. Hoods were formed on a piece of rubber with a toothstick.
      File size:
      131.9 KB
      210
  16. korvette
    korvette Member
    ...hoods for the wing connecting rods in position...
      File size:
      144.4 KB
      211
  17. korvette
    korvette Member
    ...and the oil cooler unit also in right position.
      File size:
      132.2 KB
      246
  18. korvette
    korvette Member
    Exhaust pipes
    Parts: 28 / 440
      File size:
      200.9 KB
      215
  19. korvette
    korvette Member
    some boring mass production...
      File size:
      192.6 KB
      212
  20. Stev0
    Stev0 Active Member
    I DARE you to build a 'tracked' tank this fast :).
