Messerschmitt Bf 109 F-4 - Step by step...
Discussion in 'Aircraft & Aviation' started by korvette, Nov 13, 2006.
  1. korvette
    korvette Member
    ...check the right position...
      File size:
      169.9 KB
      392
  2. Alcides
    Alcides Member
    hey, you are going fast!!! keep the pictures coming. Nice work.
  3. cardmodeler
    cardmodeler Member
    Wonderful work! You make it look so easy!
  4. GT5500
    GT5500 Member
    Yes you do make it easy and I wonder if you could make it easier for us, I really struggle to get a clean leading edge, even with moistening I get creases when I curve the leading edge. Can you please give us some pointers.
  5. cmdrted
    cmdrted Active Member
    This is fantastic work! Very precise, and looks great. You do make it look easy, but I know the type of hard work it takes to make it look so. Good job korvette!
  6. cardmodeler
    cardmodeler Member
    Yes, how do you get a smooth curve on the leading of the wing when the curve gets gradually smaller towards the wingtip? I am currently building my first airplane kit and need all the tips I can get.
  7. sparrowhawk
    sparrowhawk Member
    Boy, you are doing a wonderful job on this one. Better than any building instructions!
    Highest regards, Martin
  8. Winky
    Winky New Member
    Korvette,
    Great stuff and keep up the good work! This would be a great reference when I eventually get started on my kit. Could you give a rough estimate of the time it has taken you to get to this stage? It almost appears as if you are putting this together with robotic speed and precision.
  9. korvette
    korvette Member
    Thank you very much for your kind comments and your interest in my report. I try to answer some questions:
    -forming the leading edge: I recommend to use three to four bamboo sticks with different diameters to form slowly the right rounding of the leading edge. And I never ever touch the leading edge - no fingers, no water, nothing - just cautious work with the sticks from the backside. I´m forming small parts in my hand or on a rubber, larger parts on a thick mousepad. That´s all.
    -Time: Ohhh, difficult question - never thought about it. For now I´m working on the Bf 109 for nearly four weeks.
    and now to something completly different...
    ...and finally pull the upper layer smoothly around and glue only at the edges on the backside - no glue inside !
      File size:
      171.1 KB
      218
  10. korvette
    korvette Member
    ...and here we are...
      File size:
      188.1 KB
      226
  11. korvette
    korvette Member
    Wingtips / Wingroots
    Parts: 14 / 322
      File size:
      159.5 KB
      223
  12. korvette
    korvette Member
    ...upper wingroots - also forming with a wooden stick and using white glue to fix and to make the cardboard smooth.
      File size:
      162.6 KB
      220
  13. korvette
    korvette Member
    ...and the small stringer parts on the lower side.
      File size:
      133.5 KB
      221
  14. korvette
    korvette Member
    start building the wingtips with the lower parts. Don´t forget to prepare the outer edges well.
      File size:
      111.2 KB
      216
  15. korvette
    korvette Member
    finally the upper parts and the navigation lights.
      File size:
      188.1 KB
      220
  16. korvette
    korvette Member
    Flaps and cooling combination
    Parts: 18 / 340
      File size:
      147.3 KB
      218
  17. korvette
    korvette Member
    construction finished...
      File size:
      107.1 KB
      218
  18. korvette
    korvette Member
    Upper Flaps
    Parts: 18 / 358
      File size:
      139.7 KB
      223
  19. korvette
    korvette Member
    Step 1
      File size:
      133.7 KB
      164
  20. korvette
    korvette Member
    Lower Flaps
    Parts: 14 / 372
      File size:
      142.2 KB
      223
