Messerschmitt Bf 109 F-4 - Step by step...
Discussion in 'Aircraft & Aviation' started by korvette, Nov 13, 2006.
  1. korvette
    korvette Member
    1st...
      File size:
      133.7 KB
      278
  2. korvette
    korvette Member
    2nd...
      File size:
      157.6 KB
      281
  3. korvette
    korvette Member
    ...and the 3rd one...
      File size:
      87 KB
      278
  4. korvette
    korvette Member
    Side rudder base
    Parts: 8 / 183
      File size:
      155 KB
      282
  5. korvette
    korvette Member
    Prepared basic structure. I was using CA-glue for strengthening the small parts.
      File size:
      107.7 KB
      272
  6. korvette
    korvette Member
    The basement for the tail wheel needs some support with thin paper layers - gluing is much more easier with them.
      File size:
      78 KB
      269
  7. korvette
    korvette Member
    Side rudder I
    Parts: 7 / 190
      File size:
      146.2 KB
      270
  8. korvette
    korvette Member
    I was using a wire to keep the rudder straight while gluing the layers around.
      File size:
      174 KB
      273
  9. korvette
    korvette Member
    right in place...
      File size:
      164 KB
      239
  10. korvette
    korvette Member
    Side rudder II
    Parts: 13 / 203
      File size:
      210.7 KB
      282
  11. korvette
    korvette Member
    basic structure first...
      File size:
      78.2 KB
      277
  12. korvette
    korvette Member
    and the complete work...
      File size:
      104.2 KB
      286
  13. korvette
    korvette Member
    Next control surfaces I
    Parts: 23 / 226
      File size:
      179 KB
      278
  14. korvette
    korvette Member
    preperations are always the same...
      File size:
      128.4 KB
      275
  15. korvette
    korvette Member
    thanks god - it has the right angle...
      File size:
      144.2 KB
      279
  16. korvette
    korvette Member
    Rudders
    Parts: 20 / 246
      File size:
      154.2 KB
      281
  17. korvette
    korvette Member
    1st step...
      File size:
      156.2 KB
      275
  18. korvette
    korvette Member
    nearly finished...
      File size:
      150.9 KB
      275
  19. therapy
    therapy New Member
    Hi!
    How do You actually make the flaps, rudder and ailerons movable?
    Is the model out of the box equipped with that feature, or do you make it yourself? How are the hinges actually done? (Any closeup photos, tutorials, ?)
    Thx
  20. paper warrior
    paper warrior Member
