Messerschmitt Bf 109 F-4 - Step by step...
Discussion in 'Aircraft & Aviation' started by korvette, Nov 13, 2006.
  1. korvette
    korvette Member
    last steps for the landing gear...
      File size:
      130.1 KB
      141
  2. korvette
    korvette Member
    Now we have all parts for the landing gear.
      File size:
      162.8 KB
      144
  3. korvette
    korvette Member
    First step...
      File size:
      116.8 KB
      139
  4. korvette
    korvette Member
    First try dry, than use CA-glue for a strong and secure result.
      File size:
      101.4 KB
      133
  5. korvette
    korvette Member
    the same procedure for the wheels.
      File size:
      95.6 KB
      137
  6. korvette
    korvette Member
    now she stands on her own feet.
      File size:
      111 KB
      142
  7. korvette
    korvette Member
    tail wheel
    Parts: 11 / 559
      File size:
      158.7 KB
      136
  8. korvette
    korvette Member
    preperations as for the main landing gear...
      File size:
      133.1 KB
      197
  9. korvette
    korvette Member
    also use CA-glue and give some time to rest.
      File size:
      96.4 KB
      136
  10. korvette
    korvette Member
    that´s it - landing gear ready.
      File size:
      66.5 KB
      233
  11. korvette
    korvette Member
    small parts
    Parts: 9 / 568
      File size:
      150.5 KB
      170
  12. korvette
    korvette Member
    speed build...
      File size:
      133.9 KB
      171
  13. korvette
    korvette Member
      File size:
      82.9 KB
      170
  14. korvette
    korvette Member
      File size:
      119.2 KB
      167
  15. korvette
    korvette Member
    Spinner
    Parts: 17 / 585
      File size:
      196.4 KB
      170
  16. Rick Thomson
    Rick Thomson Member
    That is a good looking build, what type of tesaband did you use for the cockpit?
  17. korvette
    korvette Member
    Hi Rick,
    I was using overhead transparency and for connection with the frame double sided tape from TESA.
    regards,
    Jörg
  18. korvette
    korvette Member
    building every segment very carefully, the spinner develops quite well.
      File size:
      126.3 KB
      133
  19. korvette
    korvette Member
    ...here it comes...
      File size:
      60.5 KB
      125
  20. korvette
    korvette Member
    right in position...
      File size:
      64.2 KB
      204
