Matrix papermodel?
Discussion in 'Science Fiction & Fantasy' started by KGC, Oct 23, 2010.
  1. KGC
    KGC Member
    Hello to all you guys!
    I wanted to ask if you know if there are papermodel the film matrix.
    If the answer is yes, where can I find them?
    Hello and thank you
  2. chunder
    chunder Member
    I would be interested in this info as well,
    I was a set builder for this movie when it was made.
  3. Rhaven Blaack
    Rhaven Blaack ADMINISTRATOR Administrator Moderator
  4. KGC
    KGC Member
    Thank you very much guys, I gladly would take the project in hand, but unfortunately I do not know where to start! : \
  5. SEBRET
    SEBRET Member
    I would love to try, I just don't think i could do it justice.
  6. Ing. Spendlik
    Ing. Spendlik Member
    Before I started work on Jetbike I was hardly thinking about this beast:
    [​IMG]
    But the beauty of Jetbike and also fact that I have the original model of Jetbike from GW were stronger :)
  7. Kai
    Kai New Member
    Wow
    The APU looks very complicated :curse:
  8. Ing. Spendlik
    It is not so complicated as it looks like. Main frame is easy, it is all about small details which makes this thing look complicated. The only problem is the balance of the model (mostly when the arms are in straight position).
  9. kar_gg1c
    kar_gg1c New Member
    I have it
    You mean this[
    ATTACH]98328[/ATTACH]
  10. ARMORMAN
    ARMORMAN FOUNDATION CORNERSTONE
    I've been looking for the source link for that. All I've found is pirate site links.
  11. KGC
    KGC Member
  12. ARMORMAN
    I have that and the AMP suit from Avatar. As soon as I can locate the designer's home pages, I'll post them.
  13. Zathros
    Zathros Guest
    I think the Nebuchadnezzar hull isn't that bad either, but the fiddly bits would have to be right to make it right. Lots of work.
  14. KGC
    KGC Member
    Perfect thanks a lot! So I look forward to the link. But you could not load them on the forum?
    Otherwise if you can send them to me via email?
  15. ARMORMAN
    I believe, that where possible, you should honor the designer with giving him site traffic as a small thank you. If I cannot find a non-pirate link, I will post them myself.
  16. MTK
    MTK Active Member
    Both models are indeed a worthy challange, can't wait to see if they are made available. That AMP suit rocks.:thumb:
  17. KGC
    KGC Member
    ARMO Ok thanks a lot, then expect everyone to give us the news! :D
  18. Vortex_4200
    Vortex_4200 Member
    Agreed!
  19. ARMORMAN
  20. Zathros
    Zathros Guest
    X-0-LENT!!! Thanks ARMORMAN!!
