Lubin R-VIII bis 1/33 scale
Discussion in 'Aircraft & Aviation' started by eatcrow2, Jul 13, 2006.
  1. eatcrow2
    eatcrow2 Member
    1930s floatplane from " CardPlane".. Not use to doing aircraft, so it will be interesting to see if I complete this without screwing up or losing interest (something I'm quite good at). Was surprise to see how big a model this will end up being..
    pic 1 cover
    [​IMG]
    pic 2...Have glued up the formers on 1mm stock.
    [​IMG]
    pic3. cut out the floor and added some of the cockpit parts
    [​IMG]
  2. eatcrow2
    eatcrow2 Member
    Glued up part of the frames and decking pieces..
    [​IMG]
    [​IMG]
    Two side pieces and their parts added before installing..
    [​IMG]
    [​IMG]
  3. rmks2000
    rmks2000 Member
    Peter,
    Do the ribs show through the sides, or are the sides too opaque?
  4. eatcrow2
    eatcrow2 Member
    No, the ribs will not be seen from the outside.. though they will be seen from looking down in the cockpit and guntub..
  5. Alcides
    Alcides Member
    Very nice
    I'm really interested in this plane. I'm going to follow this thread wit a lot of interest.
    A question: Do you order the kit from modele-kartonowe directly?
    Regards
    Alcides
  6. eatcrow2
    eatcrow2 Member
    Hi Alcides...
    So far the kit has gone together great.. English instructions would have been nice, but I'm used to this by now.. Once I start on a part, for the most part I can usually figure it out as I'm building.. Ordered my copy from the PaperStore.
    http://www.papermodelstore.com/
    Good prices and fast delivery.
    Cheers..
  7. eatcrow2
    eatcrow2 Member
    seat
    Well I did the seat.. In cutting this out, I would cut out one of the small inter openings.. run a bead of Future around the cut.. let dry, and then cut another opening.. The Future seals and stiffens the part, so that you won't tear the thin pieces seperating the openings. Once they're cut, glue up the pieces.. let dry, and then painted with a flat aluminum.. When dry, I added the cushions after dry brushing them with a lighter leather color for more of a used look.. then a light dry brush of Future over the cushions for less of a dead flat look... Would be nice if I had a seatbelt detail for this aircraft or time period. Will hold off adding the seat until later, in case I come up with something..
    parts for seat..
    [​IMG]
    finished....
    [​IMG]
  8. eatcrow2
    eatcrow2 Member
    filling voids
    Next set of pictures show where I'm using high quality scrap balsa that I've had lying about to fill in the voids along the bottom of the frame. Do not want to end up with that "starved cow" look, that you will sometime get when covering a large area without some sort of backing. All the balsa was put in leaving about 1/16 pass the frames, to be sanded down flush to the frames when dry.. When sanded to the shape I wanted, I then painted with a blue-grey any place where there would be a joint in the skins.. An added plus, is that I'll end up with a stronger fuselage that will be able to be handled without caving in the sides..
    balsa added..
    [​IMG]
    [​IMG]
    sanded and painted..
    [​IMG]
  9. eatcrow2
    eatcrow2 Member
    side and top panels added
    Have added the side and top panel pieces.. So far the fit has been perfect, and any problems I have had, are due to my own making...
    [​IMG]
    [​IMG]
  10. eatcrow2
    eatcrow2 Member
    Thank you GB.. Have been inspired by your work and your documentation of the process..
    Peter
  11. josve
    josve Active Member
    Really a great build there Peter!!
    Will follow the rest of your report with the greatest interest!
  12. eatcrow2
    eatcrow2 Member
    gun tub
    Thank you Johnny...
    Next up is adding the gun tub.. glued up the tub sides, and then added the top ring. After cutting out the center, I stuck it back in while I glued the ring to the tub.. helps keep the shape nice and round while drying.. just pop it out when dry..
    parts for the tub..
    [​IMG]
    tub with ring added..
    [​IMG]
    finished piece..
    [​IMG]
    added to the fuselage..
    [​IMG]
  13. eatcrow2
    eatcrow2 Member
    sliding hood &rails
    Added the rails inside the cockpit, and then the hood that sits in the rails, and slides over the cockpit. The windscreen that sits on this, I will add later..
    Hood in the open position..
    [​IMG]
    Closed...
    [​IMG]
