Looking for test builders
Discussion in 'Aircraft & Aviation' started by mig29, May 17, 2006.
  1. Getter1
    Getter1 Active Member
    Close up of the tail fin details.
  2. cmdrted
    cmdrted Active Member
    This is just Fantastic! Excellant detail and excellant workmanship building it!
  3. Getter1
    Thanks cmdrted :) I'm lovin this kit and can't wait to jump into Gabriel's Mig 21. Knowing the goofs I made I want to build this one agian later on.
    I found weapons for her on Kancho's site but they are in 1/48 scale. I was wondering if someone could tell me how to adjust the percentage while printing a PDF file? That would also help me adjust my P-Model Drakken (which is 1/50) into the same scale as the Grippen.
    Getter1
  4. cmdrted
    Usually when you select print on the pdf file you get to go to your "printer properties", right before you print. Somewhere in your printer selections you get to set up the page size and sometimes as a percentage. Look for that feature then set it up as a percentage. I think to get from 1/50 to 1/72 it is @ 69% 1/48 to 1/72 is @66%.
  5. Getter1
    Well finally got back to work on the Grippen and here's this weeks results. Everything but the canopy is done :D
    Getter 1
  6. Getter1
    Underside.
  7. Getter1
    Close up.
  8. Getter1
    close up of the pylons.
  9. Getter1
    Side view.
  10. Getter1
    Thanks Golden Bear. A compliment coming from you really means a lot :)
    Getter 1
    John
  11. agrarflieger
    agrarflieger New Member
    Hello Getter1,
    well done, a wonderful work and a nice looking model.
    How do you want to build the canopy?
    best regards
    Agrarflieger
  12. Getter1
    Thanks for the compliment :D
    I've made the mold already and tried to heat up and stretch clear sheet styrene over it but I'm having difficulty heating it up properly. I'm serioulsy considering a run to Home Depot to get some clear heat shrik tubing to do your method.
    To make the mold of course I build the canopy inside out. Then filled then whole thing with Testors White model putty (I have about 5 tubes of the stuff). After curing for about a week I tossed the whole thing into a cup of water to dissolve the paper canopy and wolla :D A little sanding and a clear coat to seal it up and I got a perfect mold. Now if I can master the rest of the process. I've read a lot about molding parts but have never tried it till now :(
    Getter 1
  13. eagleone
    eagleone Member
    Washington
    Getter1 did you end up in Washington State or Washington DC? If Washington State where at?
  14. Getter1
    WA State, Spokane. About 30 minutes from Idaho.
  15. eagleone
    eagleone Member
    Wa
    Welcome to Washington. I am currently living in Western Washington(Everett).
  16. paul a
    paul a Member
    I have volunteer for your test build hope to hear from you soon thank you for the opptunaty to try a new model
  17. GT5500
    GT5500 Member
    Wow this thing is gorgeous, where can I get? :-D :-D
