Lockheed U-2R / Hobby Model / 1:33
Discussion in 'Aircraft & Aviation' started by korvette, May 11, 2007.
  1. korvette
    korvette Member
    ...built and...
  2. korvette
    korvette Member
    attached to the middle section. Now, you can see the opening for the hatch.
  3. korvette
    korvette Member
    Last step - close the openings
  4. korvette
    korvette Member
    Sensor Pod construction
  5. korvette
    korvette Member
    finished section
  6. korvette
    korvette Member
    prior to wing assembly, you have to add some framework to the wings...
  7. korvette
    korvette Member
    ...final works...
  8. Amazyah
    Amazyah Senior Member
    You perform some beautiful work, korvette!
    Keep it coming!
  9. korvette
    korvette Member
    Thank you Russell, I will do so...
    Last step, two hoods on the rear wing parts.
  10. korvette
    korvette Member
    result so far...(I)
  11. korvette
    korvette Member
  12. korvette
    korvette Member
    Senior Span Pod
    parts: 26 / 307
  13. korvette
    korvette Member
    first, the hull base for the satellite pod...
  14. korvette
    korvette Member
    the prepared pod segments...
  15. korvette
    korvette Member
    and all together...
  16. korvette
    korvette Member
    in position on the upper hull...
  17. korvette
    korvette Member
    main landing gear
    parts: 33 / 340
  18. korvette
    korvette Member
    ...building progress...
  19. Bowdenja
    Bowdenja Active Member
    OK korvette............... did I miss seeing it in your first post...............have you mixed black paint into your glue?:twisted:
  20. dansls1
    dansls1 Member
    Looking very good!
