Lockheed U-2R / Hobby Model / 1:33
Discussion in 'Aircraft & Aviation' started by korvette, May 11, 2007.
  1. korvette
    korvette Member
    Now the inner parts of the engine.
  2. korvette
    korvette Member
    Looks simple, but you have to fix the outer and inner structure perfectly for a good result...
  3. korvette
    korvette Member
    ready for asembly line...
  4. korvette
    korvette Member
    At least. I got a space problem.
  5. korvette
    korvette Member
    upper hull parts
    parts: 8 / 134
  6. korvette
    korvette Member
    First step: preperations...
  7. korvette
    korvette Member
    starting with the structure for the upper hull
  8. korvette
    korvette Member
    construction of the rudder base
  9. korvette
    korvette Member
    The whole part was glued on top of the rear segment. Some missfittings were removed with some white glue.
  10. korvette
    korvette Member
    the finished structure
  11. korvette
    korvette Member
    air intake
    parts: 24 / 158
  12. korvette
    korvette Member
    starting with the inner parts...
  13. korvette
    korvette Member
    building process of the outer parts...
  14. korvette
    korvette Member
    it was a little bit tricky to install these parts on the sides of the hull, but...
  15. korvette
    korvette Member
    ...finally with an acceptable result.
  16. korvette
    korvette Member
    rudders
    parts: 41 / 199
  17. korvette
    korvette Member
    First, the installation of the inner framework.
  18. korvette
    korvette Member
    The side rudder was glued and formed with very few white glue on the outer edges and than formed with a tooth stick.
  19. korvette
    korvette Member
    ...and here it is...
  20. korvette
    korvette Member
    the elevators were prepared almost the same way.
