little joe question
Discussion in 'Space & Aeronautics' started by NULLMOON, Mar 30, 2007.
  1. NULLMOON
    NULLMOON Member
    does anyone have a picture of the underside(engines)of the cardinspace little joe model im not quite sure how the parts are formed:roll:
  2. Carl (Surfduke) Hewlett
    Carl (Surfduke) Hewlett Active Member
    If You can wait till in the morning
    I can get You some of My build. My camera has went out. My son is coming home tonight. I will get his and get You a shot then, (If someone does not get one sooner).
    Carl
  3. NULLMOON
    NULLMOON Member
  4. CardStalker
    CardStalker Member
  5. NULLMOON
    NULLMOON Member
    thanks it was just these parts i couldnt quite work out:grin:ill post some pictures when i finish
  6. NULLMOON
    NULLMOON Member
    finished a nice easy model that goes together in a few hours the engine parts just need a drawing or picture as its difficult to work out from the text how they are formed
  7. murban
    murban Member
    Hi Nullmoon,
    I promise that I'll improve the instruction diagrams in the reworked kit.
    By the way: The Little Joe looks a little lonely on the cutting mat. Maybe I should continue this small project I found in my heap of unfinished work...
    regards,
    Michael
  8. NULLMOON
    NULLMOON Member
    reworked? guess i have to build it again then:roll:
  9. murban
    murban Member
    I guess so... especially the engines ;)
    best regards
    Michael
      File size:
      145.6 KB
      File size:
      145.6 KB
      65
  10. NULLMOON
    NULLMOON Member
    what are the other details? an inteirior:twisted:
  11. murban
    murban Member
    Yes, for the booster. As you can see in the image above, you'll have to build the complete rocket engines an put them into the booster frame. Also there were some details that I omitted in the first release: telemetry antennas, camera pods, marmon clamp and a whole range of surface details...
    Also, I will make all the different capsules and paint schemes so that you can chose which mission to build.
    regards,
    Michael
  12. Carl (Surfduke) Hewlett
    Wow!
    Can't Wait!!!!!
    Carl
  13. NULLMOON
    NULLMOON Member
    from the way the rocket is described i always thoght that it was a tube holding a bunch of smaller rockets didnt they use the lj for tests on pigs?or am i thinking of something else
  14. murban
    murban Member
    Yes, that's right - look at the image I provided above - you can see 4 big Castor/Pollux rockets and 4 small Recruit rockets that were stuffed into the Little Joe...
    No pigs on board though - only Rhesus monkeys from time to time...
    Michael
  15. NULLMOON
    NULLMOON Member
    i know there were pigs involved somewere during capsule drop tests or something of that nature
