Leman Russ Dominator (Warhammer 40K)
Discussion in 'WarHammer40k' started by Rhaven Blaack, Feb 23, 2016.
  1. Rhaven Blaack
    Rhaven Blaack ADMINISTRATOR Administrator Moderator
    So here is my second Warhammer 40-K model. The Leman Russ Dominator (Warhammer 40K).
    Here are the parts sheets.
    I decided to add extra detail as I go along through the build (starting with louvering the vents in the main body).
    I decided to detail out the gun by making the barrel look like a real barrel and raise the printed parts on the side.
    Both guns and the front hatch are attached.
    bigpetr, zathros and Famous Dave like this.
  2. Rhaven Blaack
    Here is the turret plate.
    I detailed the the side hatch.
    I raised the printed detail on the back of the turret plate.
    Here is the turret plate as a whole.
  3. Rhaven Blaack
    Here is an update on my progress.
    I added a little extra detail to the piece in the first frame. All I did was raise the vertical parts that go around the stack.
    zathros likes this.
  4. Rhaven Blaack
    I added extra detail to these parts as well. I raised the bands around the cylinder, I raised the edging around the ends of the cylinder (Just to give the parts a bit more detail), and raised the framework of the braces (That way the braces will have a bit more to hold onto the body with).
  5. Rhaven Blaack
    I decided to louver out this part to make it look a bit more realistic.
  6. Rhaven Blaack
    The only extra detail that I added to these, was to layer the exhaust stacks so that they would look more realistic and the texture would be on both the inside and outside.
    zathros likes this.
  7. Rhaven Blaack
    There was not anything more that I could do with this part. SO it is "as-is".
    zathros likes this.
  8. Rhaven Blaack
    Here is an update.
    I have started with the track assembly.
    I added the center track.
    Starting on the detail on the outside.
    I detailed the louvers.
    zathros and JanMarciniak like this.
  9. PaperAir
    PaperAir Active Member
    looking great
    Rhaven Blaack likes this.
  10. Rhaven Blaack
    Thank you!
  11. Rhaven Blaack
    Continuing on with adding extra detail.
    DSCN0264.jpg DSCN0265.jpg DSCN0266.jpg DSCN0267.jpg DSCN0268.jpg DSCN0269.jpg DSCN0270.jpg DSCN0272.jpg DSCN0273.jpg DSCN0274.jpg
    zathros likes this.
  12. Rhaven Blaack
    I created a realistic for the louvered vent.
    The vent is attached.
    Here is the door.
    The door is attached.
    more updates soon.
  13. Revell-Fan
    Revell-Fan Co-Administrator Administrator Moderator
    This looks awesome! Like in old times, buddy! :)
  14. Famous Dave
    Famous Dave Member
    Looking great. These models are fabulous by their designers, but when you take the time and effort to add the layering and detsils, they really come alive. Can't wait to see you finish.
  15. Rhaven Blaack
    Thank you!
    It is a fun and enjoyable build. There is so much that can be done with these models.
  16. zathros
    zathros -----SENIOR---- Administrator Moderator
    How did this one get buy me. You have become the "GreebleMeister"!! :)
  17. Rhaven Blaack
    Thank you. There is quite a bit of detail that I missed (but I will add it to the next build). There is still a ton of work to be done on it though.
  18. zathros
    You're never satisfied with your work. You set the bar high! :)
  19. Rhaven Blaack
    I like detailed models. :):hammerhead: :headbange:
    Granted, I may not be as good as some of the other builders that we have here. thumbsupHowever, I do the best that I can (and am always looking for ways to improve my skills).:yesyes::yesyes::yesyes:
  20. Rhaven Blaack
    Sorry for for the long time between updates. I have been dealing with a few problems in my life (more like health).
    I messed up my back at work and now facing surgery on my knee (I have a torn meniscus).
    So enough about me. On with my update.
    As you can see, I raised the printed details to the track assembly.
    I decided to double up on the tread pad parts to give them a more realistic look.
    I started to apply the treads. This is a very tedious process.
    I am putting this project on hold for a little while, as I have another project that I have to do and have it done before the middle of July. Yes, I will post the other project!
    So until next time, ENJOY!!!
    bigpetr and zathros like this.
