LeFH 18/40 1:16 DrafModel
Discussion in 'Armory & Military' started by josve, Jun 7, 2008.
Thread Status:
  1. josve
    josve Active Member
    Hello guys!!
    After half an hours rest....it's time to start the next big project!
    Since my first model from Draf was IMHO 100% perfectly designed, I just had to make the next model from Rafal as well!
    This time the LeFh 18/40 (leichte Feldhaubitze 18/40) kal.105mm
    The Kit
    [​IMG]
    [​IMG]
    I will start with the wheels.
    Here is the drawing.
    [​IMG]
    And the parts for ONE wheel ready.....157 parts just for the rim and spokes..
    [​IMG]
    First out are the spokes.Each spoke contains 9 parts.
    [​IMG]
    First I assembled the inner structure.
    [​IMG] [​IMG]
    Then I started to put the 3 covers on.
    [​IMG]
    Here are the parts for the front part of the spoke
    [​IMG]
    The part is cutted out and I will shape it half tubed
    [​IMG]
    When the two front parts are in place,the tube that will cover the rest of the spoke is shaped
    [​IMG]
    And the spoke is done....11 to go...
    [​IMG]
    zathros likes this.
  2. Soaring
    Soaring Guest
    Excellent job so far! What are you using for the inner structure?
  3. josve
    josve Active Member
    The inner structure is made of 0,5mm laserkutted karton.
  4. lriera
    lriera Member
    Johnny its very good for us that you only rest half an hour, but please take care, I want see you building a lot more models :thumb:
    Greetings
  5. josve
    josve Active Member
    With all 12 spokes done it was time to put things together.
    The spokes are placed into slots in the ring
    [​IMG]
    Then the other ring is placed
    [​IMG]
    Then it was the inside cover
    [​IMG] [​IMG]
    Some parts was to be placed around the root of the spokes.
    [​IMG] [​IMG]
    All parts glued in place
    [​IMG]
    With the center plate in place all got painted and the inner part of the wheel is done.
    [​IMG]
    zathros likes this.
  6. josve
    josve Active Member
    Continuing with making the outer part of the tyre.
    First the inside of the rim.
    [​IMG]
    When the inside was on....and it fitted 100% I'm amazed that I didn't have to trim that part,but I glued it butt to butt!!
    I made the first section of the tyre
    [​IMG] [​IMG]
    I make one section at the time since I think it's easier to have the roadside of the tyre aligned with it's proper segment....did that make any sence?
    [​IMG]
    Here is the road part of the tyre.Two smaller strips on each end and one bigger in the middle
    [​IMG]
    When the roadside was done it was time to strt cutting letters
    [​IMG]
    They make a really good 3d effect on the tyreside
    [​IMG]
    With all letters in place,the tyre was painted again with a new color I got mixed today,and it's finished on this side.
    [​IMG] [​IMG]
    Next will be the brake system.
    zathros likes this.
  7. Soaring
    Soaring Guest
    My gosh man! Doesn't making those tiny letters hurt? More importantly, how are you doing it!
  8. josve
    josve Active Member
    LOL making the letters doesn't hurt at all! I just use the knife to cut them :)
  9. josve
    josve Active Member
    Brakes.
    The drawing
    [​IMG]
    I start with the lower part.
    [​IMG]
    Then two rings are placed on top of the base.
    [​IMG]
    A coned part goes down in the hole.
    [​IMG]
    And some arrangement on top of it
    [​IMG]
    The base for the adjustment screw
    [​IMG]
    The screw in place....soryy for the blurried pic!
    [​IMG]
    And the rear side is another step closer to complete :)
    [​IMG]
    Now I'm off work for 4 weeks...going to skiathos Greece in two weeks time!!
    See you all when I'm back!
    zathros likes this.
  10. Soaring
    Soaring Guest
    Gasp! No!!!! Don't leave! WE must see more of your work! If not, at least bring your supplies with you :)
    ON another note, great job,have a safe trip, and have fun!
  11. Jim Nunn
    Jim Nunn Guest
    Johnny,
    Have a safe trip and enjoy your vacation. We all look forward to seeing the next installment.
    Jim Nunn
  12. josve
    josve Active Member
    The frame that supports the wheels and the barrelslide arrangement.Vacations are now over , and the work on the LeFh continues!!
    The drawings
    [​IMG] [​IMG] [​IMG]
    I started with building the inner structure of 0,5mm laserparts. And with the usual DrafModel presicion every piece was 100% fit.
    [​IMG] [​IMG]
    Then there was to put on the skin and add some perifer parts here and there to complete the main part of the frame.
    [​IMG]
    Added the rest of the skins,and the part is almost ready to be painted.
    [​IMG] [​IMG]
    zathros likes this.
  13. josve
    josve Active Member
    The part is done.
    [​IMG] [​IMG]
    zathros likes this.
  14. cgutzmer
    cgutzmer Guest
    Outstanding work as always Johnny!
  15. josve
    josve Active Member
    Thanks Chris!!
    I made the two supporters for the front lower arrangement that will hold some showels and other stuff.
    The drawing
    [​IMG]
    Finished parts
    [​IMG]
    Just to show where they belong I put together the parts on the right side and the drawing
    zathros likes this.
  16. josve
    josve Active Member
    Continuing with the adjustment construction ( man who knows all the names for theese parts??)
    It's the frame where the barrel will be added later....
    First a couple of drawings.
    [​IMG] [​IMG]
    Parts are glued to 0,5mm karton. Each part will be laminated out of 3 parts X 0,5mm.
    [​IMG]
    Parts ready for assemble.
    [​IMG]
    Here I have glued the parts together and the main frame is ready to come together.
    [​IMG]
    Next parts was the vertical adjustment gear.
    [​IMG]
    Inserted to the casing
    [​IMG]
    And some metalwork
    [​IMG] [​IMG]
    And some unnamed parts
    [​IMG]
    zathros likes this.
  17. josve
    josve Active Member
    Now I was to make the gears and wheel for the horizontal movement adjustment gears.
    [​IMG] [​IMG]
    Parts for the lower gearbox
    [​IMG]
    Assembled
    [​IMG]
    And inserted together with the adjustment wheel
    [​IMG] [​IMG]
    Next was the outside gearbox for the vertival adjustment.
    [​IMG]
    Part done and mounted
    [​IMG] [​IMG]
    zathros likes this.
  18. josve
    josve Active Member
    An Idea came floating along when I was making adjustment wheels.
    O-Rings!! Comes in a lot of different sizes.
    [​IMG] [​IMG]
    After mounting rest of the gear transmissions the part was done.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    zathros likes this.
  19. josve
    josve Active Member
    SOOOOO the build continues after a "little" break :)
    Continued with making the legs.
    The drawing of the inner skeleton
    [​IMG]
    The parts and the finished skeleton
    [​IMG]
    [​IMG]
    Rolling and shaping such long and coned cylinders isn't always the easyest thing to do...but with some patience and careful shaping its not that bad to make.
    [​IMG]
    Parts to be cut out, and the finished tubes
    [​IMG]
    [​IMG]
    The end plate
    Drawing
    [​IMG]
    Not very difficult to make this part.Just a few metal parts missing.
    [​IMG]
    [​IMG]
    To be continued :)
    zathros likes this.
  20. zathros
    zathros -----SENIOR---- Administrator Moderator
    I have never built one of these so I don't know about the perfection, partly because it is hidden by the perfection you have shown in building it!! Superb!! I just realized the scale, tremendous! :)
Thread Status:
